12-21-2013, 12:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1540240 Status: Offline Thanks Meter: 15 | Lumia 520 RM-914 just vibrate after flash i had lumia 520 RM-914 and i need to reset it but i tried to flash phone with same product code after flash phone now its not turning on and just vibrate only its not connecting with pc using usb plz help here is log: Code: 11:22:04 : ================================================ 11:22:04 : Advance Turbo Flasher Found 11:22:04 : ================================================ 11:22:04 : Driver Version : 00020416 11:22:04 : Library Version : 00030204 11:22:06 : Box Type : ATF Nitro 11:22:06 : Box Firmware : LogiCore 10.3.80 11:22:06 : Software Version : v10.50 11:22:06 : AdvanceBox SN : B8255E11F6E6512AC3A3CEC1 11:22:06 : Box Status : ACTIVATED 11:22:07 : ================================================ 11:22:07 : Box Successfully Initialized 11:22:07 : ================================================ 11:22:07 : 11:22:07 : VBATT Powering Down <<<< 11:22:10 : VBATT Powering Up >>>> 11:22:10 : SET VCCIO Level Done 11:22:10 : SET BSI Load Done 11:22:10 : 11:22:10 : 11:22:10 : 11:22:10 : ///////// /// /// /////// /////// ///////// 11:22:10 : /// /// /// /// // /// /// /// /// 11:22:10 : /// /// /// /////// /////// /// /// 11:22:10 : /// /// /// /// /// /// /// /// /// 11:22:10 : /// ///// /// /// /////// ////// 11:22:10 : 11:22:10 : ======================================= 11:22:10 : /// /// /// ///////// /////// ////// 11:22:10 : ///// /// /// /// /// // /// /// 11:22:10 : /// ///// /// /// /////// /// /// 11:22:10 : /// //// /// /// /// /// /// /// 11:22:10 : /// /// /// /// /// /// ////// 11:22:10 : ======================================= 11:22:10 : 11:24:31 : 11:24:31 : ====================================================== 11:24:31 : Selected VPL File: 11:24:31 : RM914_059S1N6_1030.6409.1314.1002_077.vpl 11:24:31 : ====================================================== 11:24:31 : Variant Details : RM-914 VAR IMEA IN CV 11:24:31 : Software Version : 1030.6409.1314.1002 11:24:31 : Product Type : RM-914 11:24:31 : Product Code : 059S1N6 11:24:31 : Variant Version : 077 11:24:31 : 11:24:37 : 11:24:37 : ====================================================== 11:24:37 : Flash File Checksum Verification 11:24:37 : ====================================================== 11:24:40 : RM914_1030.6409.1314.1002_RETAIL_im_india_269_02_170921_prd_signed.ffu: CHECKSUM PASSED 11:24:40 : ====================================================== 11:24:40 : Verification Done... 11:24:44 : Windows Phone 8 Flashing Started 11:24:44 : Loading Flash Files Please Wait... 11:24:45 : 11:24:45 : ====================================================== 11:24:45 : Windows Phone 8 Lumia Flasher 11:24:45 : ====================================================== 11:24:45 : 11:24:45 : If the Phone is ALIVE 11:24:45 : 1. Power On the Phone and Connect it to the USB Port 11:24:45 : 11:24:45 : If the Phone is DEAD 11:24:45 : 1. Connect Phone to the USB Port 11:24:45 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 11:24:45 : 3. Wait until the Phone Vibrates Shortly... 11:24:45 : 4. Stop Pressing the Buttons... 11:24:45 : ====================================================== 11:24:45 : 11:25:12 : IMEI: 358106055815289 11:25:12 : Version: 1.1.1.3 11:25:12 : Product Code: 059S1N6 11:25:12 : Module Code: 0205435 11:25:26 : 11:25:26 : Boot Flash Mode Successful... 11:25:26 : 11:25:26 : Phone Info Query Start... 11:25:26 : Blocks Returned: 0x07 Blocks 11:25:26 : Block ID 0x01 :00241000 11:25:26 : Block ID 0x02 :00240000 11:25:26 : Block ID 0x03 :00E90000 11:25:26 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 11:25:26 : Block ID 0x0D :0001 11:25:26 : Block ID 0x0F :0301010100000101FF 11:25:26 : Block ID 0x10 :0100030000 11:25:26 : Checking SD Card Size... 11:25:26 : Card Size: 0x00000000 11:25:26 : Checking Platform Security Status... 11:25:26 : Platform Secure Boot Status: Active 11:25:26 : Secure FFU EFUSE Status: Active 11:25:26 : Debug Status: Active 11:25:26 : RDC Status: Not Active 11:25:26 : Authentication Status: Not Active 11:25:26 : UEFI Secure Boot Status: Active 11:25:26 : Checking Secure FFU Mode... 11:25:26 : Secure FFU Mode : SYNC + ASYNC 11:25:26 : Query Flash App Information... 11:25:26 : Flash App Information: 02010C011700 11:25:26 : UEFI App: FLASH APP 11:25:26 : Flash App Protocol Version: 1.12 11:25:26 : Flash App Implementation Version: 1.23 11:25:26 : Query ROOT KEY HASH... 11:25:26 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACECAEF3F808C868FD 11:25:26 : 11:25:26 : Sending Image Signatures... 11:25:27 : Image Signatures Accepted! 11:25:27 : Erasing Data Partition... 11:25:27 : Data Partition Erased Successfully 11:25:27 : Preparing Buffers for DATA LOOP... 11:25:27 : Allocating System RAM OK! 11:25:27 : Start Sending DATA BLOCKS... 11:28:31 : ERROR: LAST DATA BLOCK REJECTED! 11:28:31 : Check your Flash File and Phone Connection 11:28:31 : ERROR: Flashing Failed! thanks |
12-21-2013, 12:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ddjadav Flash your phone with same product code and use version 3xxx.xxxx.xxxx.xxxx. Your phone is high version inside and will not accept 1xxx.xxxx.xxxx.xxxx flash files. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
