08-01-2014, 00:06 | #1 (permalink) |
Crazy Poster Join Date: Jul 2008 Location: bolivia
Member: 807029 Status: Offline Sonork: 100.1650872 Thanks Meter: 2 | Please Try Again Later (Server Busy) Now I can not change my atf .. even though it was already activated long ago. server does not work for now or what? I need some urgent information Greetings atf team Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : xxxxxxxxxxxxxxxxxxxxxxxxx oculto por seguridad ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
08-01-2014, 01:20 | #2 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | help supporters Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : B015E55***************** ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to dabing For This Useful Post: |
08-01-2014, 05:49 | #3 (permalink) |
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | thax you atf team Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : B015E************* Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
08-01-2014, 12:23 | #4 (permalink) | |
Member: 807029 Status: Offline Sonork: 100.1650872 Thanks Meter: 2 | Quote:
Collaborate Please . | |
