01-21-2014, 17:36 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Pakistan Swat Mingora City
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Nokia Lumia 620 flashing problem. when on show nokia then error. unable to found bootable option.press any key to shutdown. i am trying to flash with atf its give me error also.. IMEI: 354636053510577 Version: 1.1.1.2 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00000000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 020109011000 UEFI App: FLASH APP Flash App Protocol Version: 1.9 Flash App Implementation Version: 1.16 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
01-21-2014, 19:41 | #3 (permalink) | |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Quote:
its to heavey file got allot time in download and after its not compatible so can i have tested link file? | |
01-22-2014, 12:42 | #10 (permalink) |
Freak Poster Join Date: Aug 2010 Location: brasil -brasilia Age: 38
Member: 1379110 Status: Offline Thanks Meter: 51 | click flash then secure volume up and put the cable will begin to flash what care does the atf does best and safely then continue with atf box continues the error and try to download another version |
01-22-2014, 16:10 | #11 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @fazalrabikhan: Flash Phone with v1xxxx.xxxx.xxxx.xxxx Or Flash Phone with v3xxx.xxxx.xxxx.xxxx If both versions give you this error, than you need ATF JTAG and write BIG BOOT file with it, if after writing BIG BOOT - it still can't flash - than it is hardware problem. BR |
01-22-2014, 16:16 | #12 (permalink) |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Thanks all of you for bieng here.... My problem is still no solve but i am trying all your giving sol..... if my problem is solve with that i will post success log. if not i will still post error log... |
