08-26-2015, 15:47 | #106 (permalink) |
Junior Member Join Date: May 2008 Location: Nigeria
Member: 774985 Status: Offline Thanks Meter: 3 | Thanks in Advance! |
09-01-2015, 08:16 | #107 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2452650 Status: Offline Thanks Meter: 0 | Didn't get credits for JTAG activation Hi, I make payment with Paypal 5 days ago and I still didn't get credits. S/N: C00672718479E0A88C09553B. There is same S/N. in Paypal payment description. GiedKuc |
09-02-2015, 06:39 | #108 (permalink) |
Insane Poster Join Date: Aug 2005 Location: Venezuela Age: 45
Member: 168650 Status: Offline Thanks Meter: 5 | Emmc pinouts y300 0151 ATF Emmc pinouts y300 0151 ATF please help to repair y300 update exception emmc is readonly. reading emmc Interface Reset OK! 21:20:03 : eMMC Access Type: SECTOR MODE 21:20:03 : eMMC Supported Voltage Range: 21:20:03 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 21:20:03 : 21:20:03 : CID : 45010053454D3034479024D1A703300D 21:20:03 : CSD : D00F00320F5903FFFFFFFDFF924040C9 21:20:03 : 21:20:03 : eMMC Boot Information 21:20:03 : Revision 1.5 (for MMC v4.41) 21:20:03 : BOOT PARTITION : NOT BOOT ENABLED 21:20:03 : PARTITION ACCESS : R/W USER PARTITION 21:20:03 : PERM_BOOT_CFG_PROT : DISABLED 21:20:03 : PWR_BOOT_CFG_PROT : DISABLED 21:20:03 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 21:20:03 : RESET BUS WIDTH : ENABLED 21:20:03 : eMMC FirmW UPDATE : ENABLED 21:20:03 : EMMC CACHE SIZE : 0 KB 21:20:03 : SUPER PAGE SIZE : 3072 KB 21:20:03 : HC ERASE GROUP SIZE: 2048 KB 21:20:03 : USER AREA SIZE : 3959422976 BYTES 21:20:03 : BOOT PARTITION SIZE: 1024 KB 21:20:03 : RPMB PARTITION SIZE: 128 KB 21:20:03 : 21:20:03 : 21:20:03 : eMMC Device Information 21:20:03 : Manufacturer ID: SANDISK 21:20:03 : Device Type : Embedded BGA 21:20:03 : Application ID : 00 21:20:03 : Product Name : SEM04G 21:20:03 : Product Rev : 9.0 21:20:03 : Product SN : 24D1A703 21:20:03 : Manufactured : March 1997 21:20:03 : 21:20:03 : Card Specific Data 21:20:03 : CSD_STRUCTURE : Extended 21:20:03 : SPEC_VERS : Version 4.1/4.2/4.3 21:20:03 : TAAC : 3 ns 21:20:03 : TRAN_SPEED : 4000000 KHz 21:20:03 : READ_BL_LEN : 512 Bytes 21:20:03 : C_SIZE : HIGH CAPACITY 21:20:03 : WP_GRP_ENABLE : YES 21:20:03 : WRITE_BL_LEN : 512 Bytes 21:20:03 : CONTENT_PROT_APP : NO 21:20:03 : PERM_WRITE_PROTECT: NO 21:20:03 : TMP_WRITE_PROTECT : NO 21:20:03 : 21:20:03 : Extended CSD Saved: 21:20:03 : 45010053454D3034479024D1A703300D.ext_csd 21:20:03 : Backup Directory: 21:20:03 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
The Following User Says Thank You to wrecker01 For This Useful Post: |
10-13-2015, 18:56 | #109 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2471947 Status: Offline Thanks Meter: 1 | Need help Activating JTAG I have purchased the JTAG Activation for my ATF Box on 24 Sep 15. I have not been able to see the credits. I get the following error Default language ID 0x0409 JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...Cannot Send HTTP Request, Error 0x00002EFD I have tried on different machines and on different internet connections. Transaction ID 41926584E8023171F Box info: Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.30 AdvanceBox SN : B5C9053D81F294C478D1BEF6 Box Status : ACTIVATED ================================================ Box Successfully Initialized I've tried the reset options as described with no luck. |
12-20-2015, 23:30 | #110 (permalink) |
Junior Member Join Date: Nov 2013 Location: Shinjuku Age: 47
Member: 2064266 Status: Offline Thanks Meter: 0 | Hello Admin Users My problem with my Jtag activation is still an issue because my ATF nitro has not the jtag activaved.Can you please do something for me thank you. Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.50 AdvanceBox SN : C10E8EA8EB69DDFADD7651D7 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ JTAG Module: NOT ACTIVATED JTAG Module Activation Cost: 39 Credits ERROR: You DO NOT HAVE enough Credits! Purchase JTAG Credits at ATF Store |
12-21-2015, 12:55 | #111 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have payed the 39 credits?, if yes show transaction. If no is write clear: Quote:
BR allumts | |
12-31-2015, 20:24 | #112 (permalink) |
Member: 2064266 Status: Offline Thanks Meter: 0 | Hi I've already payed via paypal here my payment here is my serial C10E8EA8EB69DDFADD7651D7 thank you , I have paid via paypal. transaction number of payment is 19R20397R29225115 made on 08/19/14 Can you please help me and see what is the issue because when I log my ATF nitro there is only 1 credit and not the 39 as expected. thank you rgds GKILL2K7 |
03-15-2016, 14:04 | #113 (permalink) |
Major Poster Join Date: Feb 2013 Location: Chennai Age: 31
Member: 1883363 Status: Offline Thanks Meter: 7 | Hai bro i having issue while actiavting jtag activation while i clicked on activate jtag means i get this error bro JTAG Module: NOT ACTIVATED JTAG Module Activation Cost: 39 Credits ERROR: You DO NOT HAVE enough Credits! Purchase JTAG Credits at ATF Store what can i do bro |
03-26-2016, 19:22 | #114 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 49
Member: 152153 Status: Offline Thanks Meter: 19 | JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...A connection with the server could not be established PLEASE SOLVE MY PROBLEM |
05-26-2016, 09:58 | #116 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2047179 Status: Offline Thanks Meter: 31 | BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED i tried restore box restore eeprom update software and firmware but problem still. please help urgent |
The Following User Says Thank You to harpindersingh For This Useful Post: |
07-22-2016, 14:48 | #117 (permalink) |
Freak Poster Join Date: Aug 2005 Location: sibiu
Member: 167213 Status: Offline Thanks Meter: 21 | Default language ID 0x0409 JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...Cannot Send HTTP Request, Error 0x00002EFD Help solution please.. |
08-06-2016, 06:53 | #118 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2238106 Status: Offline Thanks Meter: 1 | Default language ID 0x042A JTAG Interface ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...A connection with the server could not be established why this prob lem i actived it before please check me |
02-16-2017, 09:40 | #119 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2673014 Status: Offline Thanks Meter: 1 | Hello, I'm trying to use the JTAG module and when i press for activation I'm getting this error JTAG Module: ACTIVATED Checking Activation String... ERROR: JTAG Activation Failed! 0XF855 can anyone help me? I have v12.67 and last firmware on the ATF box |
