03-04-2014, 08:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | <<<<<<<< ATF JTAG - Box Init Failed - Solution >>>>>>>> If you have Activated ATF JTAG and you are getting an error: Box Init Failed! Then you must follow steps below to fix your problem: 1. Make sure NO OTHER BOXES ARE CONNECTED TO USB PORT 2. Make sure ONLY 1 ATF BOX IS CONNECTED TO USB PORT 3. Go to "Product Support" ---> "Box Tools" ---> click "Restore EEPROM" 4. Disconnect ATF Box from USB Port 5. Close ATF Software (AdvanceBox.exe) 6. Connect ATF Box to USB Port 7. Run ATF Software (AdvanceBox.exe) 8. Wait until USB Drivers are installed... Then close ATF Software 9. DO NOT ACTIVATE JTAG USING ATF Software!!! *** Make sure you Internet Connection before proceeding to the Next Step... 10. Run ATFJ.exe (ATF JTAG Software 1.06 or higher...) If your problem is still not solved, read Step 9... Repeat 1 to 10 again. If your problem is STILL NOT SOLVED, then Post your problem here. B.R. |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
03-04-2014, 08:17 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Brother you said click on Restore EEPROM while in picture indication is on Restore BOX .... what to do Restore EEPROM or Restore BOX ?? Last edited by Winner58; 02-01-2015 at 20:50. Reason: quote removed |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
03-04-2014, 16:22 | #13 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Santo domingo norte villa mell
Member: 398011 Status: Offline Thanks Meter: 25 | help unlock 610 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...Timeout During Operation! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...Timeout During Operation! |
03-04-2014, 19:08 | #15 (permalink) |
Junior Member Join Date: Nov 2004 Age: 34
Member: 90245 Status: Offline Thanks Meter: 0 | Hello, i have did already the steps from first post and no lucky. When i try to activate from ATFJ.exe I have internet connection, i stoped all firewall/antivirus and etc. Is there any solution ? |
