<<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> Make sure you are using ATF JTAG v1.0.11 or Higher versions... Download FFU_FLASHER.afp for your phone model via ATFJ.exe built-in downloader "Help" ----> "Updates" http://174.120.45.27/tmp/FFU_FLASHER_STEP_0.jpg Download Lumia Flash Files (FFU) for your Phone's Product Code: http://forum.gsmhosting.com/vbb/f609...added-1660094/ Follow Steps I described in the pictures below. Make sure FFU File you use is 100% not corrupted and is 100% match to your product code! STEP 1 - Select FFU_FLASHER.AFP for your Phone http://174.120.45.27/tmp/FFU_FLASHER_STEP_2.jpg STEP 2 - Solder JTAG Wires to Phone. Click "RESET JTAG" and make sure the Phone is Detected http://174.120.45.27/tmp/FFU_FLASHER_STEP_1.jpg STEP 3 - Click "CUSTOM R/W", then select "Write" http://174.120.45.27/tmp/FFU_FLASHER_STEP_3.jpg STEP 4 - Select FFU File which matches your Phone's Product Code http://174.120.45.27/tmp/FFU_FLASHER_STEP_4.jpg STEP 5 - Click "OK" http://174.120.45.27/tmp/FFU_FLASHER_STEP_5.jpg STEP 6 - Just Click "OK" http://174.120.45.27/tmp/FFU_FLASHER_STEP_6.jpg STEP 7 - Wait until all Partitions are Written http://174.120.45.27/tmp/FFU_FLASHER_STEP_7.jpg STEP 8 - Perform USB Flashing via ATF Software B.R. |
