Atf lighting problem TODAY WHEN I OPENED MY BOX GET THIS ,I TRIED TO RESTORE BUT IN THE END GET ERROR HOW TO SOLVE THE PROBLEM? ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ |
Hi, Check in Device Manager, if you can see ATF Box Ports or not... And let me know. |
i see "advancebox programing port" and "advancebox turbo flasher" in universal serial bus controllers |
Connect ATF Box directly to PC USB Ports (if its connected with USB HUBS). Remove/Reinstall ATF Box Drivers. |
ı same problem directyl usb ports remove atf box drivers but not usb 2.0 mode help me |
Which type of box you have ? Have you restore your box ? Br - srinibas |
call me i am solve your problam 03337308933 |
Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 |
