atf lightning cant read sd card <<< SOLVED >>> tried all types/kind/sizes of mucro sd but still the same,, tried other sd reader still the same, im using 4in1 v2 adaptor. cant use my sdc unbricker ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:12 ERROR: WRITE FAILED! tia |
Use only Good and not Fake SD CARD like Samsung, San Disk, itc... ORIGINAL and size must be same or more high of size of Sdc file...if Sdc file require 32GB Sd Card you must need 32gb of ORIGINAL Sd Card...with Fake Cina card you have problem....Adapter work 100% if isn't been damaged. BR allumts |
yes im using class 10 sd cards, 16 32 and 64 but the same results over n over,, is it maybe theres a problem with my atf lightning? what possibly the problem? hardware maybe. coz updated restored few times but still the same. |
Post Full log and screenshot...let me see what show in Sw |
BR allumts |
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : ################# Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Initialize SDC Module ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! ================================================== ==== Loading ATF SDC File... (Please Wait) ================================================== ==== SDC File Version: v11.30 SDC File Author: CDD4066FBBCF8B108C0A6EB0 Date Created: 06/05/2014 (dd/mm/yyyy) Description: Samsung SM-N9005 UNBRICK 4.4.2 ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Reset Micro SD Card... Total Elapsed Time 00:00:13 ERROR: WRITE FAILED! used all voltage same result |
hi should the green light of the atf should blink coz the orange liught only is the one blinking, but the light of the adaptor is ok,,, |
If you think socket is OK then SD card defected Br -- srinibas |
fully working sd card,, the sd cards have been used in some deadboot phones using sdc in other atf from my friend,, the problem is its mine aint workin,, the adpter continusly blink after clicking yes in this log SDC File Version: v11.30 SDC File Author: CDD4066FBBCF8B108C0A6EB0 Date Created: 06/05/2014 (dd/mm/yyyy) Description: Samsung SM-N9005 UNBRICK 4.4.2 then failed |
Hi, this Sdc file above require 16/32GB of Sd card what size are using? Try with other NEW not used Sd Card if you are sure that adapter is fully working, i doubt becouse isn't Atf sw that not see this card but reader or damaged Sd Card... Not import if are used for other phone one sd card can damage. Already try with other Sdc file for test If loock here there are 4/5 Sdc file and if not use right size Sd Card can get error: http://www.4shared.com/folder/w9n0Nu...sortsMode=NAME |
Loock, Sdc file tested in this moment for you and at first time with ORIGINAL San Disk 16GB sd card Sw work fine, (i not use adapter becouse Big Atf), so not think is you Atf problem, ceck good Sd Card and Adapter side, loock: http://i1366.photobucket.com/albums/...psfn4mjxfh.png BR allumts |
1 Attachment(s) where does the green wire connected to? i think thats the problem when i open my atf,, and the green light on the fbus dont light http://forum.gsmhosting.com/vbb/atta...1&d=1440407607 thanks |
Sorry but if you have just open this Atf Light and cut cable ask to X-Shadow at this point...if you not had touched nothing can be i can help you with other test but at this point not want any responsability for mistake....sorry P.D. anyway from above logs not was seem that Atf had problem, not understan why have open first of other easy test primary... BR allumts |
Br - srinibas |
thanks srinibas,,, sd reader is the problem. |
