Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 01-20-2011, 12:23   #76 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
is usb flashing possible?
does not see usb port?
Old 01-20-2011, 12:36   #77 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hello, USB port also not in ATF box - so we uses computer usb port to work with. )
With ATF lighting - same, connect usb cable in PC, select USB Mode in software and you are done!
Old 01-20-2011, 12:41   #78 (permalink)
Member: 643472
Sonork: 100.96901
Nokia 2690c flashed successfuly with ATF Lighting,,,
ATF Software Version v6.50
ATF Lightning FBUS Flash Started...
Number of Image Files: 3
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.60.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 1165
Entry Point: 0x5047
Page Format : -1
MAX PAGE : 0x00004000
Changing MODE : FLASH
VBATT OFF...
VBATT ON
Setting VBATT Done!...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 66977256 (0xE8) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 06500103
ID DWORD 1 : 0A974950
ID DWORD 2 : 08C1BAB5
ID DWORD 3 : 3CA161CE
ID DWORD 4 : 9973037B
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 43
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_2nd.fg
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : FFFFFFFFFFFFFFFFFFFF
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 1C
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :0000
RAP3Gv3_algo.fg
First Algo byte : C0
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
No PAPUBKeysHash Returned
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
No partition info....
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x36 (54)
ERASE Blocks : 0x01 (1)
0 ERASE_AREA_BB5 0x12
Block Length : 0x33 (51)
BB ASIC Index : 0x00 CMT
Device Type : 0x00 NOR
Device Index : 0x00
0 : 00000000-000006BF
1 : 000006C0-0001FFFF
2 : 00040000-000BFFFF
3 : 000C0000-0013FFFF
4 : 00140000-0137FFFF
5 : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 14 STATUS_NOR_OK_BB5
Block Length : 01
BB ASIC Index : 00
Successfully erased..
Time Taken to Erase : 00:01:15
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDRand2TX
Flashing Speed: 15.00 Mhz
Processing : rm635__10.60.mcusw
Total blocks to write : 1165
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
Block Length : 01
BB ASIC Index : 00
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:58
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.60.ppm_uab
CMT Type : BB5
Number of Blocks : 204
Entry Point: 0x00B6
Page Format : -1
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x0E (14)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01520000-01DBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:00:15
Processing : rm635__10.60.ppm_uab
Total blocks to write : 204
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:09
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.60.image_uab_pink
CMT Type : BB5
Number of Blocks : 456
Entry Point: 0x00C8
Page Format : -1
Using Internal VPP
StartErase_DCT5...
BlockLength : 0x16 (22)
Block Length : 0x13 (19)
Device Index : 0x00
0 : 01DC0000-0215FFFF
1 : 02160000-03FBFFFF
Block Length : 01
BB ASIC Index : 00
Time Taken to Erase : 00:03:39
Processing : rm635__10.60.image_uab_pink
Total blocks to write : 456
Block Length : 01
BB ASIC Index : 00
Time Taken to Flash : 00:00:21
Total Flash Write Time (Flashing Only) : 00:01:29
Total Flashing Time (Booting + Erase + Flashing) : 00:06:42
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
MCU: V 10.60 10-06-10 RM-635 (c) Nokia
IMEI: 358260036745311
Model : Nokia 2690
Product Serial Number: DUH400789
Product Code : 0592078
Module Code : 0204458
Basic Production Code: 0589255
Default SN Type : 0
MCU SW Version : V 10.60 10-06-10 RM-635 (c) Nokia UAB
BT MCM Version : 2.31-SP2.26
PPM Version : V 10.60 10-06-10 RM-635 (c) Nokia
HW Version : 1000
RFIC Version : 06540601
DSP Version : ICPR72_10w06
LCD Version : SUEZ
Content Pack Version : Content: uab_pink V 10.60 10-06-10 RM-635 (c) Nokia
AHNE Version : 30
Retu Version : 16
Tahvo Version : 22
******** Reading SimLock ********
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST MODE
Dynamic Camera Configuration
DCC ID : NI00IIIIRR030C213402
DCC Ver: 003002
Status : OK
FACTORY SET TO : Factory Set Full
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Production Tune
OK
FACTORY SET TO : Production Tuning
OK
FACTORY SET TO : Reset User Code
OK
FACTORY SET TO : Service Centre
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : User Data
OK
RESET LIFE TIMER TO : 0000:00
OK
Old 01-20-2011, 13:17   #79 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
Originally Posted by soroar View Post
Thomas
hi what about the sl3 Launch ac we dont need the ATF Lightning Launch now need sl3 support not same of mxkey do like that now using 2 x ATi5850, they produce ~2450M hases/sec. (oc'ed), vs one 5850 (~1200M h/s)
- for curiosity i put calculation on my old ATi 4770 (640SP),
and it produces around 400M hashes/sec (4min, 15 sec per chunk),
card is clocked at 850MHz gpu ok[/QUOTE]
That is the only way of SL3 bruteforce. No other choice. If you want fast then u need to buy HD5970 x 2 with water cooling
Like in the photo:
Thomas
The Following 3 Users Say Thank You to gsmfun For This Useful Post:
Old 01-20-2011, 14:54   #80 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
Thumbs down
Originally Posted by Advance-Box View Post
Please this is not SL3 thread.
I guess now people realize that it is hard to make money out of SL3 unlocking.
You buy super PC for about 2K - 4K USD...
Then you pay for additional 2 kilowatts electricity everyday...
In the end, sometimes cannot even find the code!!!
And for what??? 15-30 usd that customer is willing to pay you?
How many phones do you need to unlock in order to get Return Of Investment???
If you have 4K usd to buy super pc, better put the money in the bank... This is the
reality of the current SL3 Bruteforce Solution. I hope everyone can stop pretending
that they can actually earn money from SL3 BF Unlock.. Really, please stop it...
we need Solution without Bruteforce Solution we went to use the same pc then ?
Old 01-20-2011, 15:02   #81 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
There is no solution without Bruteforce yet!!
Thomas
Old 01-20-2011, 15:04   #82 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
when ever we found solution without bruteforce then sure we will add it in ATF
The Following User Says Thank You to Javajohn For This Useful Post:
Old 01-20-2011, 15:09   #83 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Thomas
But good will be that you add bruteforce to ATF becouse all other box include new one like cyclonebox not have 64bit drivers and can't work on it in new windows 7 64bit and only avalible box that got 64bit drivers and work on w7 64bit is ATF and will be good to add BF to software to users that want do this can work without problem in new computer with 4GB or more RAM and new graphic cards support if you add like HD6970 becouse now all this is missing soon will be HD6990 and too not supported and all old hardware card now are very hard to catch on market new one with good price better is buy new card but now not supported by any box becosue all use free sw to calc BF SL3 noone want add new cards why ?? This is so hard to relise BF for all nokia box programers ?? ?? ??
Old 01-20-2011, 15:14   #84 (permalink)
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
INFINITY NOKIA BEST is not use the Bruteforce Solution then what the use you know that the all so Launch sl3 unlock so ?
Old 01-20-2011, 15:40   #85 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
I tested with MXkey work with win7 64bit 6300 hash which with 2 x 5970 water cooling full overclock.
Cyclone i think need to click F8 should work? I didn't test yet.
For local burteforce we will consider about it.
The main thing i think BF is not so hard but programming GPU is That is why no team really deep inside this. All using free sw. For HD card i think still best is HD5970 as can see in the table of Ivan blog.
Thomas
The Following User Says Thank You to gsmfun For This Useful Post:
Old 01-20-2011, 15:43   #86 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
If Infinity not using bruteforce what they using? I think you better check in their section.
Old 01-20-2011, 15:56   #87 (permalink)
Member: 1489869
The manual on removal of blocking of Nokia 1280 is necessary
Old 01-20-2011, 17:12   #88 (permalink)
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
bro we r toking about the sl3 unlock ok not 1280
Old 01-22-2011, 00:58   #89 (permalink)
Member: 1441285
Thanks Meter: 3
wow , really this is a good Product for Nokia power Hungry phones.
i hope hardware quality will be batter then old one .
BR,
Xploreunlock
Old 01-22-2011, 03:37   #90 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
Originally Posted by MGT SOFTWARE View Post
the mode of USB if broken where will get new hardware, i said so because do always USB cable damage obvious you can repair by replacing to new one , how about this?
I understand, You mean USB tail of the ATF. Yes, they have made a mistake to put Fix USB cable attached to the BOX. This can be broken any time or comes problem anytime. At that time, what we have to do?? Throw ATF or .............??? Actually, in my openion, the team must make this like UFS using A to B extension cable to the BOX's Female Port. If A to B cable get problem we can throw it and put another cable.
This is only for suggestion to the team. Don't take it as negative way.
Ericsson Mobile Office DI-27 pornopig Old Ericsson Phones & Sony Phones 1 11-06-2001 05:37
New Unlocking Hardware Site Launched logosunlimited Main Sales Section 0 10-17-2001 01:00
Ericsson Mobile Office Suite V 1.1 andbel Old Ericsson Phones & Sony Phones 0 06-29-2000 22:22
Ericsson Mobile Office Suite Aldrin Old Ericsson Phones & Sony Phones 1 11-21-1999 18:14
Page generated in 0.40355 seconds with 9 queries
