Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-05-2016, 17:05   #1 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 157
ATF Nitro Auto update problem
Hello Sir i download latest version 12.60 and want to update auto but when i press "check software update" nothing change on software and when i restore box, error server shows
please guide me what to do
thanks
Old 04-05-2016, 17:17   #2 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,687
atf server are updating ... will be online in 24-48hours dns propagation
The Following User Says Thank You to Smart-gsm For This Useful Post:
Old 04-05-2016, 17:30   #3 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 157
ok but i was trying to update for last 1 week
Old 08-08-2016, 15:21   #4 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 157
i buy new ATF box (used)
need to update box firmware but same error " server error"
Old 08-08-2016, 15:39   #5 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 287
my turbo box infineon all mobile flashing error - other box flashing mobile 100% ok
atf box 1 error
Data Sections : 04
Current File : rm837__03.32.mcusw
Compile Name: rm837__03.32.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 27266440 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 31B4
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
ERROR: Erasing Failed
2 error
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
ERROR: PBL was NOT Accepted
3 error
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
ERROR: ReqFlashId FAILED A
other box flashing Done
Insert USB Cable to Switched OFF Phone and Power ON
IF_USB: XGOLDxxx
IF_SBL: XGOLD213, Ok
IF_EBL: Quantum_Bootloader_10.50_M1S1 10.50, Mode: CC
FL_ID : EC001230, Samsung K5N1258ACM 512Mb
MCU FLASH BUNDLE: rm837__03.32.mcusw
Flash File: rm837__03.32.mcusw_ebl_psi.fls
Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00
Erase Area: 0x40040000 - 0x4005FFFE, Erased: 00:00
Write Area: 0x40040000 - 0x4005FFFE, Written: 00:00
Erase Area: 0x40060000 - 0x4015FFFE, Erased: 00:00
Write Area: 0x40060000 - 0x4015FFFE, Written: 00:01
Erase Area: 0x40280000 - 0x41BBFFFE, Erased: 00:54
Write Area: 0x40280000 - 0x41B3FFFE, Written: 00:31
Erase Area: 0x43E20000 - 0x43E5FFFE, Erased: 00:00
PPM FLASH BUNDLE: rm837__03.32.ppm_m2
Flash File: package_m2.ppm_ebl_psi.fls
Erase Area: 0x41BC0000 - 0x421BFFFE, Erased: 00:08
Write Area: 0x41BC0000 - 0x41EC7122, Written: 00:04
CNT FLASH BUNDLE: rm837__03.32.image_m2_059P7C1
Flash File: package_m2_059P7C1.image.fls
Erase Area: 0x421C0000 - 0x43E1FFFE, Erased: 01:07
Write Area: 0x421C0000 - 0x430DFFFE, Written: 00:19
Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:02
Flashing Done: 03:14
ShutDown Done
Old 08-11-2016, 16:50   #6 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 157
still server error
i need to update box, box is not working without update.
Old 08-14-2016, 17:13   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,145
Originally Posted by darmobiles View Post
still server error
Hello, read Sticky Threads next time.
Here my Full solution Tested and working 100%:
http://forum.gsmhosting.com/vbb/f609...-here-2090299/
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 08-21-2016, 09:03   #8 (permalink)
darmobiles's Avatar
Member: 1675429
Sonork: 1609235
Thanks Meter: 157
allumts
Thanks for solution.
problem solved.
realy we are lazy users
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.15264 seconds with 7 queries
