Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-07-2014, 07:59   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,604
ATF Nokia X Simlock IMEI v11.20 Update!! Public Discussion Thread:
Release Date: April 7, 2014
Firmware Version Required : 11.0.00
Nokia X Android Ultimate Tool
ATF Uses a Built-in ADB Layer and it will Shutdown any Running
ADB Servers on your PC if it finds anything running. You DO NOT
NEED TO INSTALL ADB and FASTBOOT. You DO NOT NEED tO enter any
codes to the phone just to read phone info Just install the
correct Nokia X Drivers from:
C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\
Nokia X Android Flash Engine
--> Supports Normal Phone and Dead Phone Flashing
--> Supports Flashing Custom Images (LEWA OS, TWRP Recovery etc.)
--> Supports Manual Flashing for:
Kernel, BOOT, RECOVERY, MODEM, UDISK, USER DATA, VARIANT, and PRELOAD Partitions
Nokia X Android ROOT Kit - First In The World for 1-Click OFFLINE Solution
--> Just a 1 Click Solution
--> Supports Nokia X Firmware version 10.0.3 and 11.1.1
--> NO NEED INTERNET CONNECTION - 100% OFFLINE and less than 5 Seconds
--> Also supports Samsung, HTC, LG and other brand ROOTING
Nokia X Android Google Service Installer - First In The World for 1-Click Solution
--> Installs Google Services on ROOTED Phone
--> Installs Google Store, TTS, Hangouts and other Important Google Services
--> Optionally Installs KitKat 4.4 Launcher to improve Nokia X User Interface
--> Fully Tested and Optimized for Nokia X vesion 10.0.3 and 11.1.1
Nokia X Android IMEI and Simlock Backup and Restore - First In The World
--> Reads and Saves Encrypted EFS and NVBK (Requires ROOT)
--> This EFFECTIVELY Saves the Phone's IMEI, SIMLOCKS and other Important Tuning Values
--> Saves in PLAIN BINARY FORMAT
--> Writes EFS and NVBK Backup to Phones (No ROOT Required)
--> Can be used to Fix/Repair IMEI and Simlock of Phones
*** DO NOT USE THIS FOR ILLEGAL PURPOSES SUCH AS IMEI CLONING
NOkia X other BASIC FUNCTIONS Supported - First In The World
--> Easily Switch between Normal, Recovery and Bootloader Modes
--> Reads Phone Info in Normal Mode
--> Reads eMMC Partition Info in Bootloader Mode
Infineon XG-221
--> Fixed Flashing Support for Asha 230 and 230 DS
--> Added Support for Asha 230 and 230 DS Decrypt PM 120
Other Changes
--> Fixed ATF JTAG Activation Button
--> Complete Product Listing in Nokia.ini as of April 7, 2014
ATF JTAG 1.0.7 Build 3919
Change Log
* Added Support for Custom eMMC Read/Write
--> Supports ALL Nokia WIN7 and WIN8 Devices except Lumia 1520 and Lumia Icon
--> MSM7x27A, MSM8x55T, MSM8x25, MSM8x27, MSM8x60, MSM8x30
--> Saves Dumps in PLAIN BINARY Format
* Added Nokia X RM-980 FULL BOOT REPAIR - First In The World
* Added Cherry Mobile Flare 2.1 FULL BOOT REPAIR - First In The World
* Added Starmobile Diamond V3 FULL BOOT REPAIR - First In The World (Thanks to Mark Pineda)
* Added Samsung I8150 FULL BOOT REPAIR
* Added Samsung I8552 FULL BOOT REPAIR
Download Official AFP Files Here:
http://www.4shared.com/folder/c0N1po2w/ATF_JTAG_AFP_FILES.html
Special Thanks
--> For this update we give special thanks to WAJID who tested Nokia X Rooting
--> Special thanks to Chainfire for a WONDERFUL SuperSU.apk
--> Special thanks to Kasha*****a for preparing the Google Services Tweak
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
The Following 62 Users Say Thank You to gsmfun For This Useful Post:
Old 04-07-2014, 08:01   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
ROOTING NOKIA X 10.0.3 and 11.1.1 in 1 Click
BEFORE DOING THE STEPS BELOW:
1. If you Updated ATF via the Autoupdate Server, then it means you DO NOT HAVE ROOTING and GOOGLE Services Files on your PC.
You need to download and install this:
ATF_ANDROID_ROOT_AND_GOOGLE_Installer - Download - 4shared - Linus Hernandez
or this
Download links for ATF_Android_ROOT_and_GOOGLE_Installer.rar - Mirrorcreator - Upload files to multiple hosts
2. If you get "Index Out Of Bounds" Error, you need to:
2a. Open C:\AdvanceBox Turbo Flasher\AdvanceBox.ini using NOTEPAD
2b. Add 2 lines on the bottom of the file. Type it manually or just copy paste below:
 [ANDROID]
 PhoneSelectedIndex=0
2c. Close Notepad and select YES when it asks you to save the file.
NOKIA X Drivers are here:
http://174.120.45.27/tmp/NOKIA_X_USB_DRIVERS.rar
Step 1:
Step 2:
There is no more Step 2... you are Done!
B.R.
The Following 38 Users Say Thank You to Advance-Box For This Useful Post:
Old 04-07-2014, 08:01   #3 (permalink)
Member: 651945
INSTALLING GOOGLE SERVICES and KITKAT 4.4 LAUNCHER for NOKIA X 10.0.3 and 11.1.1 in 1 Click
Step 1:
Step 2:
B.R.
The Following 29 Users Say Thank You to Advance-Box For This Useful Post:
Old 04-07-2014, 08:01   #4 (permalink)
Member: 651945
Backup IMEI + SIMLOCKS + Tuning Values for NOKIA X 10.0.3 and 11.1.1 in 1 Click
FIRST IN THE WORLD
Step 1:
Step 2:
B.R.
The Following 21 Users Say Thank You to Advance-Box For This Useful Post:
Old 04-07-2014, 08:02   #5 (permalink)
Member: 651945
RESTORE IMEI + SIMLOCKS + Tuning Values for NOKIA X 10.0.3 and 11.1.1
FIRST IN THE WORLD
*** DO NOT USE THIS TO CLONE OTHER PEOPLES IMEI AND SIMLOCKS !!! YOU WILL GO TO JAIL***
Step 1:
B.R.
The Following 17 Users Say Thank You to Advance-Box For This Useful Post:
Old 04-07-2014, 08:13   #6 (permalink)
The_Killer's Avatar
Member: 601608
Sonork: 100.1590021
Thanks Meter: 150
just an awesome update as always
will that support unlock for nokia android based phone ??
and remove pattern without loss data ???
The Following 2 Users Say Thank You to The_Killer For This Useful Post:
Old 04-07-2014, 08:13   #7 (permalink)
shadigsm's Avatar
Member: 280342
Thanks Meter: 73
Please supporter Activate ATF JTAG Activation.
Transaction ID for this payment is
sn 851332d3a
851332D3D88220F7B571F9A7
The Following User Says Thank You to shadigsm For This Useful Post:
Old 04-07-2014, 08:21   #8 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 941
please link download for new update.....
The Following User Says Thank You to Deni's For This Useful Post:
Old 04-07-2014, 08:24   #9 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
Download link not update
The Following User Says Thank You to sunilkumar70791 For This Useful Post:
Old 04-07-2014, 08:27   #10 (permalink)
Member: 1761687
Sonork: 100.1669047
Thanks Meter: 494
Where we can get USB drivers for New Nokia Android models?
10x
The Following User Says Thank You to Mr.Firmware For This Useful Post:
Old 04-07-2014, 08:27   #11 (permalink)
Member: 1761687
Sonork: 100.1669047
Thanks Meter: 494
10x
Old 04-07-2014, 08:29   #12 (permalink)
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
auto update in atf exe
Old 04-07-2014, 08:30   #13 (permalink)
shadigsm's Avatar
Member: 280342
Thanks Meter: 73
JTAG Module: NOT ACTIVATED
JTAG Module Activation Cost: 39 Credits
ERROR: You DO NOT HAVE enough Credits!
Purchase JTAG Credits at ATF Store
Old 04-07-2014, 08:35   #14 (permalink)
Member: 1078009
Thanks Meter: 12
Change Log
OMG!!! THANK YOU SO MUCH for Custom Read/Write Emmc!!!
AWESOME!!!!!
The Following 5 Users Say Thank You to lordmaxey For This Useful Post:
Old 04-07-2014, 08:38   #15 (permalink)
Member: 651945
@fawad85
Add in last line in bottom
[ANDROID]
B.R.
P.S.
If you updated only via AUTO UPDATE SERVER, you will need to download the
ROOT and GOOGLE Files here:
or here
If you do not install this, then you cannot ROOT or Install Google Services.
The Following 12 Users Say Thank You to Advance-Box For This Useful Post:
Page generated in 0.26023 seconds with 9 queries
