01-08-2015, 00:59 | #62 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2087998 Status: Offline Thanks Meter: 0 | PLEASE help for activation. Advance-box ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.88 AdvanceBox SN : 84C38A9481A56ED6E9479F29 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-18-2016, 15:44 | #63 (permalink) |
Registered User Join Date: May 2009 Location: syria
Member: 1029548 Status: Offline Sonork: 12345 Thanks Meter: 3 | ====PLEASE help for activation. Advance-box ============================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : E1C5F6309EFF65D39675AD7A Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
10-12-2017, 10:51 | #64 (permalink) |
Junior Member Join Date: Apr 2003 Location: Russia Age: 46
Member: 26169 Status: Offline Thanks Meter: 0 | Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. Box worked all time. last 7 years. And I dont remember the name of reseller. Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : ACC336FD85349392EC934ABC How can I fix htis problem? |
10-12-2017, 11:02 | #65 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | Quote:
C:\Windows\System32\drivers\etc | |
07-21-2020, 08:47 | #66 (permalink) |
Insane Poster Join Date: Nov 2008 Location: IRAN
Member: 891319 Status: Offline Sonork: 100.1578664 Thanks Meter: 20 | pleaz active Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 90EDAE099A86A09B8A7DC26E |
07-21-2020, 10:44 | #67 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Bangladesh
Member: 1497712 Status: Offline Thanks Meter: 83 | Atf-box not activated Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EC359186A80BA1BDB4D3E1EB ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ |
09-17-2020, 13:06 | #70 (permalink) |
Junior Member Join Date: Aug 2007
Member: 561134 Status: Offline Thanks Meter: 0 | plz Advance Turbo Flasher Found ================================================ Driver Version : 00020802 Library Version : 00030200 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BCAF1ACB948829D29C278717 ========================================= Please Try Again Later (Server Busy) ========================================= |
09-17-2020, 13:17 | #71 (permalink) |
Member: 561134 Status: Offline Thanks Meter: 0 | Please help me solve this problem. ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020802 Library Version : 00030200 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BCAF1ACB948829D29C278717 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
09-18-2020, 18:07 | #72 (permalink) | |
Freak Poster Join Date: Mar 2017 Location: Moskow
Member: 2691652 Status: Offline Thanks Meter: 60 | Quote:
There are products that have died but continue to work. For example, UFS-Hwk. I often work with it. So let's not spam. People are looking for solutions in product revitalization, that's all. Google translate | |
The Following User Says Thank You to BOSSVORS For This Useful Post: |
09-19-2020, 21:16 | #73 (permalink) |
Member: 561134 Status: Offline Thanks Meter: 0 | Please Try Again Later (Server Busy) ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BCAF1ACB948829D29C278717 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
