ATF please update your box firmware problem fix <<< SOLVED >>> 2 Attachment(s) Change USB cable and re-install drivers; Disable Anti Virus during this , better put in exclusion list uninstall and reinstall ATF setup but same problem plz help me ATF ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ |
100% ftdi drivers Problem! br Polaco |
same prablem my box ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done please help team |
Same problem, after update new version http://i46.tinypic.com/10ws12w.jpg and http://i49.tinypic.com/2exrp53.jpg now my box cannot use how to slove? BR |
@ sumatera RESTORE BOX firmware & post result Br - srinibas |
i did restore box http://i48.tinypic.com/29bzqz4.jpg this log Quote:
but same problem. And i did too: 1. un install & erase folder atf, antivirus and firewall off 2. install again new version 3. restore box again still same please help me:confused::confused::confused: |
Hi, Try to update box firmware on other PC. BR |
having the same problem like yours now ::((( ..::Angel::.. --- i will try to update my box on a newly formatted pc now. I'll post the result later |
yes bro problem still not update firmware please fix Mr.Thomas this bugs |
other PC same problem plz help me |
yes i have same problem on two pc. pls.solve. |
Try with other pc result same, try with difference os (win 8) result same. Please fix this issue. BR |
plz urgent help solve this problem ATF themes plz |
sir please help urgent |
I have similar problem although message says check firmware I tried retore and also tried update but says firmware up to date. under Nokia Tab shows below list ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ |
