Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-05-2013, 15:17   #1 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Angry N8 after downgrade Write CMLA Key - Failed <<< SOLVED >>>
Hi ATF team,
Got this N8 for user lock as I did not have the latest firmware I tried to downgrade it by erasing and then reflashing the older firmware
I followed the following Steps
1. Backup RPL - IMEI and LOCKS->IMEI->Backup RPL
2. Backup Full PM - PM/PP->Read Full PM and simlock data in IMEI tab
3. Full Erase Phone - Flashing->EraseFlash->Scan->Erase
4. Write Flash with lower version - Flashing->WriteFlash - ENO needed for supported models
5. Write Backup RPL - IMEI and LOCKS->IMEI->Write RPL
6. Authorize Phone - ATF Network->Login to account-> Authorize a BB5 NEW HASH Phone
7. Repair SD and Writing PM Backup - PM/PP->Stand Alone SX4->SX4 PM Authorization->Select PM Backup
However I get CMLa keys failed every time I try also tried repairing the keys via ATF network it does says fixed but and not sort out the problem, Now the phone stuck on three dots blinking
             Basic Phone Information
MCU Version: V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia
IMEI Plain : 35739804*******
IMEI Spare : A357398047******
IMEI SV    : 335739804********F
Phone Model: Nokia N8-00
Category   : Classic Phone
Phone Type : RM-596
      SX4 Custom Keys Stand Alone Edition
>>> : SX4 Auth Successfull
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\3573980475*****\SL3_certificate_V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia_357398047******_Not Locked_103005.pm
Start Uploading PM...
Field : 120 Sub : 0 Byte(s): 944  - Ok
Field : 120 Sub : 1 Byte(s): 160  - Ok
Field : 120 Sub : 2 Byte(s): 132  - Ok
Field : 120 Sub : 3 Byte(s): 112  - Ok
Field : 308 Sub : 1 Super Dongle Key Found
Field : 308 Sub : 1 Write Super Dongle Key - OK
Field : 308 Sub : 1 CMLA Key Found
Field : 308 Sub : 1 Write CMLA Key - Failed
PM  Upload Done!...
Plz advice how to fix this
frenzy
Old 03-05-2013, 15:41   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
Repair CMLA KEY DATA from IMEI and LOCKS tab.
Old 03-05-2013, 15:52   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Authorize the phone & use " repair CMLA KEY " Simlock tab of IMEI & Locks
Br - srinibas
Old 03-05-2013, 16:04   #4 (permalink)
Member: 789089
Sonork: 100.1617***
Thanks Meter: 267
Br - srinibas
I did that, however the problem was in my firmware, Sorted it out
thanks anyway, for the great support
frenzy
Old 08-11-2014, 16:45   #5 (permalink)
Member: 2236334
Hi friend
I've been reading your post here
http://forum.gsmhosting.com/vbb/f609...olved-1624011/
I did a downgrade on a Nokia 603 and I also have the same CMLA keys not found, how did you fix it?
I was able to install only 12 version of firmware which is Belle FP1 but If I try to put 11.030.0609 which is Belle Refresh the phone is stuck with the three dots loading.
How did you fix it?
Old 08-11-2014, 19:41   #6 (permalink)
Member: 643472
Sonork: 100.96901
Originally Posted by GarzaAlfredo View Post
Hi friend
How did you fix it?
You have solution in post #2 of this thread....
Old 10-29-2014, 16:51   #7 (permalink)
Member: 1463928
Thanks Meter: 11
It's possible to repair CMLA Key with USB conexion?
Old 10-29-2014, 16:56   #8 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Yes, just authorize phone first via ATF Network
Page generated in 0.31969 seconds with 8 queries
