10-29-2014, 13:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: DHAKA
Member: 808657 Status: Offline Sonork: 100.1590300 Thanks Meter: 112 | Lumia 720 Dead Boot Repair Done With Atf Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1101003030384739320061D8126D4042 Flash Description: Toshiba 008G92, 7.28 GiB, SN 61D8126D, Apr 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5955 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 7m 51s. Code Download Speed 368 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059S207 Module Code: 0205354 Basic Tranceiver Code: 059R0L8 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6012.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: 26323C81CFBFD503F6C530F0EA1C2E7A34039581A56274F9FC C73E1B9E272887 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:50 |
