02-15-2021, 08:03 | #16 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Aegean Sea
Member: 1520712 Status: Offline Thanks Meter: 19 | thank you!!!! Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 941913E0E002DB78929E690F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized |
07-13-2021, 23:10 | #17 (permalink) |
Junior Member Join Date: May 2014
Member: 2189405 Status: Offline Thanks Meter: 0 | Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B58FF72AC3AB4853D958DC91 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-14-2021, 00:29 | #18 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Quote:
Br, xerraco | |
07-14-2021, 14:01 | #19 (permalink) |
Insane Poster Join Date: Sep 2003 Location: BUENOS AIRES--ARGENTINA
Member: 39836 Status: Offline Thanks Meter: 2 | Please A.T.F ....Thanks ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : E24231BC8C8EB843CD82C71F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-27-2021, 06:34 | #20 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | All Friends ATF Box is Dead use ATF_v8.90 working 70% of mobiles Download Here Best Regards .::Mustafa::. |
The Following 3 Users Say Thank You to .::Mustafa::. For This Useful Post: |
08-17-2021, 17:55 | #21 (permalink) |
Junior Member Join Date: Oct 2006 Location: Algeire/EL-oued Age: 38
Member: 363376 Status: Offline Sonork: 100.1620874 Thanks Meter: 1 | Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021234 Library Version : 00030216 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : A22B64AC9B8663A38842CE51 Box Status : NOT ACTIVATED |
