02-09-2014, 07:27 | #5 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 257131 Status: Offline Thanks Meter: 13 | no error indicate but always ...... in this process.. 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK |
02-09-2014, 07:35 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | @raie You are missing correct logs because you did not have correct language file that matches with current Version of ATFJ.exe That is why there are some invalid characters in your logs. This means you did not delete ATFJ.ini This means you did not follow POST #2 So I cannot help you. BEcause I do not see the error messages |
02-09-2014, 07:42 | #8 (permalink) |
Member: 257131 Status: Offline Thanks Meter: 13 | how about this logs sir... Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found. |
02-09-2014, 08:22 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,119 | @raie Yes, now is ok... Initializing Device...OK Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found. Here is Solution: 1. Disconnect USB Cable 2. Put Battery and Power ON Phone Normally until it finish entering WP Menu 3. Power OFF Phone Properly, via Pressing Power button and sliding arrow down. Dowload this: LUMIA_610_610C_UNLOCK - Download - 4shared And use that to unlock phone instead |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-09-2014, 09:10 | #11 (permalink) | |
Member: 257131 Status: Offline Thanks Meter: 13 | Quote:
