Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-29-2016, 09:16   #151 (permalink)
Member: 965470
nice udate team..tnx
Old 04-30-2016, 11:36   #152 (permalink)
UnReality's Avatar
Member: 48396
Thanks Meter: 82
Can't update ATFJ.exe. Can someone upload it anywhere?
Thanks in advance.
BR.
Old 04-30-2016, 11:44   #153 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Thanks in advance.
BR.
Wath want update if have just Last build installed? obvius get this Error, you Jtag is just update.
allumts
Old 04-30-2016, 13:07   #154 (permalink)
UnReality's Avatar
Member: 48396
Thanks Meter: 82
allumts
Ok. Why then it checked in update window? Anyway thanks for info.
BR.
Old 08-20-2016, 18:07   #155 (permalink)
Member: 2225865
Thanks Meter: 38
SM-G901F Dead boot, detecting by USB in Qualcomm HS-USB QDLoader 9008.
ATF team need your advice on it.
Thanks
Old 08-21-2016, 06:15   #156 (permalink)
farsi_007's Avatar
Member: 472592
Sonork: 100.1664052
Thanks Meter: 180
i have a Samsung e500h in hand, which has dad due to downgrade from 5.1.1 to 4.4.x.
Now the phone only vibrates while trying to download, vol- +power+menu.
Sometimes when battery fully drain and i connect to charger, it shows charging symbol.
Modem port and MTP port are still shown in device manager.
i made sdc file from 4 file firmware of 5.1.1 and burn it to 16 gb mmc through ATF SDC, and inset it to mobile and then VOL-+Menu+Power button, it restart and vibrate but not showing download mode, condition is still the same..
Please Help Team
thanx in Advace.
WBR
Old 09-16-2016, 05:57   #157 (permalink)
Member: 1741973
Thanks Meter: 115
lumia 640 LTE RM-1073 Cricket unlock supported?
Old 09-28-2016, 12:53   #158 (permalink)
Member: 1103601
Sonork: 100.1592177
Thanks Meter: 39
lumia 640 rm-1073 after flash phone dead , i tried usb boot repair but fail
please help me..................pls
Old 10-14-2016, 12:54   #159 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
lumia 640 rm 1074 flight mode solution with atf box
Old 10-23-2016, 00:06   #160 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
How to
Originally Posted by gsmfun View Post
ATF 12.67 AutoUpdate
Release Date: February 26, 2016
** YOU CAN ONLY DOWNLOAD THIS VIA THE AUTO-UPDATE SERVER **
This update addresses ATF Nitro/Lightning New Box Activation Problems due to bad DNS in certain countries.
Nothing else was changed.
Download this update if you have Activation Problems ONLY.
B.R.
X-Shadow
ATF 12.66 AutoUpdate
Release Date: February 15, 2016
eMMC Tool 5.00 (PRO)
--> Added Support for eMMC Flashing (Direct Write) for Samsung Exynos 7 Octa 7580 Based Phones
Check Tutorial Here for SM-J700:
http://forum.gsmhosting.com/vbb/f609...shing-2052359/
Samsung SM-J7008
Samsung SM-J700F
Samsung SM-J700H
Samsung SM-J700K
Samsung SM-J700M
Samsung SM-J700P
8/F/H/K/M/P
Samsung SM-A310F
Samsung SM-A310M
Samsung SM-A310N0
Samsung SM-A310Y
Samsung SM-A5108
Samsung SM-A510F
Samsung SM-A510K
Samsung SM-A510L
Samsung SM-A510M
Samsung SM-A510S
Samsung SM-A510Y
Samsung SM-A710F
Samsung SM-A710K
Samsung SM-A710L
Samsung SM-A710M
Samsung SM-A7100
Samsung SM-A710S
Samsung SM-A710Y
Samsung SM-G903F
Samsung SM-G903FD
Samsung SM-G903M
Samsung SM-G903W
Samsung SM-T670
Samsung SM-T677A
Samsung SM-T677K
Samsung SM-T677L
Samsung SM-T677V
--> Now you can Repair DEAD BOOT Repair these phones via eMMC Connection.
--> Just Download the NEWEST Firmware from
www.s-a-m-m-o-b-i-le.com and WRITE it
--> to your phone via eMMC Connection. This will repair both BOOT1 and BOOT2
--> Partitions.
Image Tool - Samsung Unbrick Image Creator 3.0
--> Added Support for 4 More Exynos CPUS:
Samsung Exynos 5 Hexa 5260
Samsung Exynos 4 Quad 4415
Samsung Exynos 3 Quad 3475
--> Now you can Create SD Card Unbrick files for phones Based on these CPUs.
Release Date: February 5, 2016
Firmware Version Required : 11.0.10 or 11.0.12
ATF Box USB Driver Required: 2.12.06 - Windows 10 (32-bit and 64-bit) - Available in Windows Driver Update Server
ATF Box USB Driver Required: 2.12.06 - Windows 8.1 (32-bit and 64-bit) - Available in Windows Driver Update Server
ATF Box USB Driver Required: 2.12.06 - Windows 8 (32-bit and 64-bit) - Available in Windows Driver Update Server
ATF Box USB Driver Required: 2.12.06 - Windows 7 (32-bit and 64-bit) - Available in Windows Driver Update Server
ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
Introducing the EASIEST Method to DOWNLOAD the NEWEST Lumia Firmware Files... NaviSearch!
Lumia Firmware Search and Download
* Very Simple Interface, select via Variant List or Product Code List
* Complete Variant Packs (Product Codes) of all Lumia phones including Lumia 950 XL, 950 and 550.
* Download via ATF Built-in Downloader or Export Download List to your favorite Download Managers
* Download STOP and RESUME Function
* Automatically verifies Downloaded File Checksum
* File Download is done in the background... You can flash phones etc while downloading files.
*** FOR NOW, NaviSearch is only Enabled for LUMIA PHONES. It will Enabled in the future for older BB5 Phones ***
New Phones Supported for Dead Boot Repair via USB Cable Only
(Most of these Models are First in the World)
Lumia 950 XL (RM-1085)
Lumia 950 XL DS (RM-1116)
Lumia 950 (RM-1104)
Lumia 950 (RM-1105)
Lumia 950 (RM-1118)
Lumia 550 (RM-1128)
Lumia 550 (RM-1127)
Lumia 640 LTE DS (RM-1113)
Lumia 640 DS DTV (RM-1109)
Lumia 640 DS (RM-1077)
Lumia 640 LTE DS (RM-1075)
Lumia 640 (RM-1073)
Lumia 640 LTE (RM-1072)
Lumia 640 XL DS (RM-1067)
Lumia 640 XL (RM-1066)
Lumia 640 XL LTE (RM-1062)
Lumia 1030 (RM-1052)
Lumia 1030 (RM-1051)
Lumia 1030 (RM-1050)
Lumia 820 (RM-826)
Lumia 625 (RM-943)
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
hi i want to boot repair by usb Nokia 640 rm 1073 which is now supported... but how can i do that?
Old 10-26-2016, 11:51   #161 (permalink)
Member: 2457203
Hello is samsung SM-T211 supported in atf jtag?
Old 10-30-2016, 08:47   #162 (permalink)
ripon074's Avatar
Member: 2097333
Sonork: 100.1675582
Thanks Meter: 44
nice update tnx atf team
Old 11-09-2016, 05:28   #163 (permalink)
Member: 1409682
Thanks Meter: 8
All users are expected ATF JTAG update!
ATF Team pls update...
Old 11-09-2016, 06:56   #164 (permalink)
tavo_unlock's Avatar
Member: 817412
Sonork: 1618066
Thanks Meter: 69
version 12.67 no flashing windows mobiule 8 nokia 520 faile faile flash ??
Old 11-09-2016, 07:10   #165 (permalink)
Member: 2434476
Thanks Meter: 3
siiipppppppppppppppppppppp............
Page generated in 0.23575 seconds with 9 queries
