09-30-2014, 16:47 | #19 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
Download from here ATF Offcial Support Area / | |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
09-30-2014, 17:08 | #20 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Here Is Problem ATF Team?? ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software WBR. Arsalan gsm2000. |
09-30-2014, 17:12 | #21 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @.::MASTER ALONE::. Go to The ATF Network tab Click "Add ATF Servers to Windows hosts File" button Also possible, you did not install FULL 11.70... |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-30-2014, 17:20 | #22 (permalink) | |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
Here ATF Servers Domain Names Already Added... But??? Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done WBR. Arsalan gsm2000. | |
09-30-2014, 19:18 | #24 (permalink) |
No Life Poster Join Date: Oct 2004 Location: italy
Member: 85139 Status: Offline Thanks Meter: 68 | ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ |
