04-06-2013, 14:57 | #122 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: Russia. city Khasavyurt Age: 42
Member: 128322 Status: Offline Thanks Meter: 13 | Quote:
04-07-2013, 08:15 | #123 (permalink) |
No Life Poster Join Date: May 2008 Location: Bangladesh
Member: 782943 Status: Offline Sonork: 100.1601067 Thanks Meter: 204 | pls help to repair contact service nokia 2700c ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-561.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 70 - Ok Field : 1 Sub : 2 Byte(s): 70 - Ok Field : 1 Sub : 3 Byte(s): 70 - Ok Field : 1 Sub : 4 Byte(s): 70 - Ok Field : 1 Sub : 5 Byte(s): 276 - Ok Field : 1 Sub : 6 Byte(s): 276 - Ok Field : 1 Sub : 7 Byte(s): 276 - Ok Field : 1 Sub : 8 Byte(s): 276 - Ok Field : 1 Sub : 9 Byte(s): 384 - Ok Field : 1 Sub : 10 Byte(s): 384 - Ok Field : 1 Sub : 11 Byte(s): 384 - Ok Field : 1 Sub : 12 Byte(s): 384 - Ok Field : 1 Sub : 13 Byte(s): 384 - Ok Field : 1 Sub : 14 Byte(s): 384 - Ok Field : 1 Sub : 15 Byte(s): 384 - Ok Field : 1 Sub : 16 Byte(s): 384 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 16 - Ok Field : 1 Sub : 20 Byte(s): 32 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok PM Upload Done!... here is the full phone info : Basic Phone Information ================================================ MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia IMEI Plain : 354192032327642 IMEI Spare : A354192032327640 IMEI SV : 33541920323276455F Phone Model: Nokia 2700 classic Category : Classic Phone Phone Type : RM-561 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 PPM SW Version : V 09.98 06-09-10 RM-561 (c) Nokia QA BT MCM Version : 2222-302 MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia RFIC Version : 06540601 DSP Version : ICPR72_09w26 LCD Version : SEIKO Content Pack Version : Content: qa_black V 09.98 06-09-10 RM-561 (c) Nokia AHNE Version : 30 RETU Version : 16 TAHVO Version : 22 Bluetooth ID : 00:26:68:2E:56:9C CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST |
04-09-2013, 18:03 | #125 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 911152 Status: Offline Thanks Meter: 4 | what about those phones of which the flash can't be read? has this been fixed? there are a bunch of models which return error when trying to read flash, i guess no ENO files from there? |
04-09-2013, 22:44 | #128 (permalink) | |
Banned Join Date: Apr 2013
Member: 1910709 Status: Offline Thanks Meter: 1 | where is download link Quote:
where is download link | |
04-09-2013, 23:11 | #129 (permalink) | |
Junior Member Join Date: Apr 2008 Location: Poland Age: 37
Member: 755974 Status: Offline Thanks Meter: 9 | Just read! This is problem for you? Quote:
The Following User Says Thank You to jayu0 For This Useful Post: |
04-11-2013, 05:15 | #132 (permalink) |
No Life Poster Join Date: Jul 2001 Location: handline Age: 48
Member: 5397 Status: Offline Thanks Meter: 38 | Why did rpl delete the telephone without a rescue? Asked it, that rescue rpl? I do I pushed it! And the imei 123456... The backup into a library there is not rpl!!! What is the solution? Where find rpl? This expensive entertainment from the part of atf! grrrr |
04-11-2013, 10:05 | #134 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Post software logs, please! BR | |
