Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-20-2012, 11:06   #196 (permalink)
Crazy Poster
Member: 501308
Thanks Meter: 3
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
ERROR: Connection Refused 0x03
Check your Test Point Soldering!
Total Elapsed Time 00:00:09
check TP ok.
Old 09-20-2012, 11:53   #197 (permalink)
IM8
Member: 694535
Thanks Meter: 69
Originally Posted by Advance-Box View Post
@IM8
Rewire your connections to use shorter wires and thinner 0.10 mm gauge for most
part of the wiring.
Too many CRC Failures means the connection is not stable and communication fails
9 out of 10 times for each sector.
My wiring suggestion is like this:
Original FBUS cable wires = maximum 1 inch Max
0.10 mm Gauge coated jumper wire = 4 inches Max
B.R.
i don't think it's a problem with the wires because i can repair boot with them .... i tryed today to short them but same error
any other solution ?
Old 09-20-2012, 12:50   #198 (permalink)
Member: 256978
Thanks Meter: 72
* Can Request and Retrieve iDevice IMEI Network Information with 1 CLICK
iOS Network Provider Info: 1 iCredits, ok, i tried and my credit, 5 credit is goon. WTF. way is that. ??????????????????????
Old 09-20-2012, 14:09   #199 (permalink)
traxgsm's Avatar
Member: 636518
Thanks Meter: 175
Originally Posted by shahzaadbutt View Post
can u help me about flashing plz?, drivers problem
http://forum.gsmhosting.com/vbb/f609...s-msm-1538781/
Old 09-20-2012, 14:32   #200 (permalink)
Crazy Poster
Member: 501308
Thanks Meter: 3
Interface Reset OK!
check TP ok.
pls pls pls reply fast. i am stuck.
Old 09-20-2012, 15:34   #201 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,415
TP not correct
no more help
Old 09-20-2012, 16:12   #202 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,117
Fixed and refunded you,, thanks for reporting.
B.R.
Old 09-20-2012, 18:37   #203 (permalink)
kabirhossain's Avatar
Member: 271880
Sonork: 100.1578866
Thanks Meter: 1,289
@MDK23
Flash phone with Known AMSS file
Flash AMSS file only, using the + MCU button in ATF and select either one of the files
RM801_11412_amss
RM801_12w27_prod_generic_amss
RM801_12w22_prod_generic_amss
RM801_12w22_1_prod_generic_amss
RM801_12w14_prod_generic_amss
RM801_12w07_prod_generic_amss
RM801_12w07_2_prod_generic_amss
RM801_11w50_1_prod_generic_amss
RM801_11w45_1_prod_generic_amss
RM801_11w41_4_prod_generic_amss
These AMSS versions I have tested all
Please Post All Lumia Unlockable AMSS version.
Old 09-20-2012, 18:50   #204 (permalink)
Member: 180091
Thanks Meter: 61
Lumia 800 unlock done not accept pin
I tried to unlock nokia lumia 800, but after successfull flashing amss file downloaded from navifirm, phone unlocked successfuly but still locked. Can the team give a tested amss file that works better with each models of phone, so one can flash them first before proceeding for unlocking? As desoldering and resoldering may damaged phone.
I downloaded this amss file but after unlock, phone still lock and failed to accept pin code.
Help will be appreciated.
Old 09-20-2012, 18:58   #205 (permalink)
..::AdnanRaj::..'s Avatar
Member: 298948
Sonork: 100.1661166 (AdnanRaj)
Thanks Meter: 641
Thank You ATF Team nice working
Keep it up
Old 09-20-2012, 20:07   #206 (permalink)
Member: 651945
version 1750.0805.8773.12220_017
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-21-2012, 01:40   #207 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 383
With version 1750.0805.8773.12220_017 unlock successful and pin 00000000 is accepted.
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
   the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 80
Application ID : 0000
Product Name   :
Product Rev    : 0C
Product SN     : 006011C6
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
Patch Byte Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:05:47
Thanks to ATF team.
Old 09-21-2012, 12:11   #208 (permalink)
yousha's Avatar
Member: 17689
Sonork: 100.72392
Thanks Meter: 737
00:06:15 : Dumping AMSS FAT16 Region
00:06:15 : Please wait for 2-4 Mintues...
00:10:20 :
00:10:20 : WARNING: Patch Bit NOT FOUND!
00:10:20 : Maybe Phone is already UNLOCKED!
I have the same problem and i also cant flash with the unlockable version ATF keep giving me message DEVICE INTERFACE SWITCHED SUCESSFULLY but cant proceed?
Windows Phone Flashing Started
AMSS File Found:
RM801_11412_amss.esco
WARNING: OSBL File is not Loaded
WARNING: MODEM ADSP File is not Loaded
WARNING: WPOS File is not Loaded
WARNING: UA ERASE File is not Loaded
Factory Reset Skipped!
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
Switching to NOKIA MODE
Polling Ports... (Please Wait)
phone is locked atf cant unlock it
what maybe the problem
The Following 2 Users Say Thank You to yousha For This Useful Post:
Old 09-21-2012, 13:19   #209 (permalink)
Member: 180091
Thanks Meter: 61
Will phone relock if after unlocking, a full flash performed on the phone?
Regards.
Moreover someone should kindly upload the said amss file lumia 800 (rm-801)
The Following User Says Thank You to adebam For This Useful Post:
Old 09-21-2012, 14:22   #210 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 383
Regards.
Phone will relock if you flash phone after unlocking.
Use Navifirm and download version 1750.0805.8773.12220_017
Fully flash phone with this version and unlock with ATF.
Good luck!
The Following User Says Thank You to fun For This Useful Post:
Page generated in 0.19411 seconds with 8 queries
