01-30-2015, 18:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | --[B][o][x]--[N][o][t]--[A][c][t][i][v][a][t][e][d]-- 1. Upgrade Your ATF Software to 11.90 which you can download here: ATF_v11.90_Full_Installer.rar 2. Update Your Box Firmware to 11.0.10 via ATF 11.90 which you downloaded from Step 1. 3. Show Complete LOGS of Error Message Moderators will AUTOMATICALLY DELETE POSTS if: 1. You are showing Logs from ATF Software which is LOWER than 11.90 2. You are showing Logs from ATF Firmware LOWER than 11.0.10 3. You are not showing COMPLETE LOGS 4. Your problem is NOT related to Box Activation 5. If you Blah Blah too much... |
The Following 15 Users Say Thank You to Advance-Box For This Useful Post: |
01-30-2015, 19:01 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Here is Example of Correct Post: Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : D951C663B7DFF86EC12D9ABA Box Status : NOT ACTIVATED IF Your Post DOES NOT LOOK LIKE ABOVE, it WILL BE DELETED AUTOMATICALLY. |
The Following 6 Users Say Thank You to Advance-Box For This Useful Post: |
01-31-2015, 09:25 | #3 (permalink) |
Registered User Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Hi Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Box Type : AJF Lightiing Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : 828CADCD4AEB9FB995DB99FE ERROR: Invalid Reply Detected... 0xB003 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ============================================== Box Sn now shows 00000 |
02-01-2015, 07:22 | #4 (permalink) |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: Box Successfully Initialized ================================================ ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : 8E1D3522856DFAF5C299FE00 ERROR: Invalid Reply Detected... 0xB003 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software Hope You Solve My Problem Soon |
02-01-2015, 08:04 | #5 (permalink) |
Insane Poster Join Date: Aug 2014 Location: Yemen
Member: 2233182 Status: Offline Sonork: 100.1658712 Thanks Meter: 18 | Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ‡TF Nitro9 Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : F17F497C963DC71BCEAF3969 ERROR: Invalid Reply Detected... 0xB003 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ************ ATF Box EEPROM Updated ************ Please Restart ATF Software... Install NEW ATF Box Drivers if needed... ************ ATF Box EEPROM Updated ************ Plus this errors 1-After restore box a)The parameter is incorrect b)The requested source is in use c)The handle is invalid 2-When Activating 'N1' is not an interger value |
02-01-2015, 08:19 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @xtreme @muzammal mudass @omi17 @baalwy 1. DISCONNECT ATF BOX from USB Port 2. Run AdvanceBox.exe version 11.90 without BOX Connected 3. Go to "Product Support" ----> "Box Tools" 4. Make sure "ATF Nitro / Light" is selected on the right side *** NOW CONNECT ATF BOX TO USB PORT *** 5. Click "Restore Box" and wait 2 to 5 minutes... *** After Restore Box is Done, it will tell you to UPDATE FIRMWARE 6. Click "Update Firmware" and wait 2 to 5 minutes... This way, box will be FULLY RESTORE Just like Brand New from Factory. |
02-01-2015, 08:20 | #7 (permalink) |
Member: 2233182 Status: Offline Sonork: 100.1658712 Thanks Meter: 18 | FEEL THE POWER...ATF BOOOOOMS AND ROCKS ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : F17F497CE13DC7BCCEAF3969 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : F17F497CE13DC7BCCEAF3969 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ STEPS -RESTORE EEPROM -RESTORE BOX -UPDATE FIRMWARE -AUTO ACTIVATED |
The Following User Says Thank You to baalwy For This Useful Post: |
02-01-2015, 14:42 | #8 (permalink) |
Freak Poster Join Date: Dec 2006 Location: india
Member: 420870 Status: Offline Thanks Meter: 11 | hello sir hi my atf box is activated Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.80 AdvanceBox SN : EA25BAE5F8E04E73E7CB07EA Box Status : ACTIVATED ================================================ my jtag is also activated but authorize bb5 is not higlighted in my box .. how to authorize it . please send me info |
02-01-2015, 20:49 | #10 (permalink) |
Freak Poster Join Date: May 2014
Member: 2189966 Status: Offline Sonork: 100.1653836 Thanks Meter: 164 | Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : E00FE0AEDB31A9F3C8906950 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
02-02-2015, 10:38 | #12 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163778 Status: Offline Sonork: 246 Thanks Meter: 1 | ATF not active Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : B583728789701FFE894D1CAD Box Status : NOT ACTIVATED date: 2013-11-22 |
02-02-2015, 14:22 | #13 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2335963 Status: Offline Thanks Meter: 0 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : CB95BFC4B0280CC0D05AD693 Box Status : NOT ACTIVATED |
02-03-2015, 02:16 | #14 (permalink) |
Junior Member Join Date: Aug 2014 Location: rio blanco , nicaragua
Member: 2240524 Status: Offline Thanks Meter: 1 | need help with this issue *************************************** Connecting to : 59.148.208.118 >> Connect timed out. *************************************** Connecting to : 59.148.208.118 >> Connect timed out. 10:17:24 : Advance Turbo Flasher Found 10:17:24 : ================================================ 10:17:24 : Driver Version : 00021200 10:17:24 : Library Version : 00030209 10:17:26 : Box Type : ATF Nitro 10:17:26 : Box Firmware : LogiCore 11.0.10 10:17:26 : Software Version : v11.90 10:17:26 : AdvanceBox SN : A9E8C139F050D62093F59871 10:17:26 : Box Status : ACTIVATED 10:17:26 : ================================================ 10:17:26 : Box Successfully Initialized 10:17:26 : ================================================ 10:17:27 : 10:17:27 : VBATT Powering Down <<<< 10:17:30 : VBATT Powering Up >>>> 10:17:30 : SET VCCIO Level Done 10:17:30 : SET BSI Load Done 10:17:30 : |
02-03-2015, 04:24 | #15 (permalink) |
Member: 1163778 Status: Offline Sonork: 246 Thanks Meter: 1 | ATF not active Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : B583728789701FFE894D1CAD Box Status : NOT ACTIVATED date: 2013-11-22 restore box ok,update frimware ok but activation not avaiable.please help me |
The Following User Says Thank You to laodai1983 For This Useful Post: |
