03-11-2015, 14:33 | #32 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
Hi, Activate Box 2 Times now. | |
03-11-2015, 14:35 | #33 (permalink) | |
Install FULL ATF 12.00 from here: ATF_v12.00_Full_Installer.rar | |
03-19-2015, 09:56 | #34 (permalink) |
No Life Poster Join Date: Oct 2009 Location: kashmir Age: 34
Member: 1134507 Status: Offline Sonork: 100.1607956 Thanks Meter: 201 | Sir X shadow pls check my box ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.92 AdvanceBox SN : E659033C836E45D2D5372CDF Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-20-2015, 14:33 | #35 (permalink) |
Major Poster Join Date: Jun 2004
Member: 68487 Status: Offline Thanks Meter: 15 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.06 AdvanceBox SN : F1C644A3AF28D4F0F416AFD7 Box Status : NOT ACTIVATED |
03-24-2015, 22:05 | #36 (permalink) |
Junior Member Join Date: May 2010
Member: 1314082 Status: Offline Thanks Meter: 0 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ************************************************** *********** Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : D26077C5B3D443F7904338CE Box Status : NOT ACTIVATED |
03-26-2015, 00:15 | #37 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1735397 Status: Offline Thanks Meter: 0 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : E6E52E33C723BBB9D71FFF08 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ |
04-01-2015, 13:31 | #38 (permalink) |
Freak Poster Join Date: May 2003 Location: Ivory coast Age: 47
Member: 28749 Status: Offline Thanks Meter: 48 | hi all team, ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.10 AdvanceBox SN : AD672611C5926F8FBDBDC882 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done thanks. |
04-03-2015, 02:33 | #40 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163778 Status: Offline Sonork: 246 Thanks Meter: 1 | ATF not active ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.10 AdvanceBox SN : 9A954A53F387D5C991105A73 Box Status : NOT ACTIVATED 2014-08-22 restore box ok,update frimware ok but activation not avaiable.please help me resseller: hoangthong mobile |
04-09-2015, 11:17 | #41 (permalink) | |
When did you buy your BOX? | |
04-09-2015, 11:18 | #42 (permalink) | |
Can fix your problem if you give me both information correctly. | |
04-09-2015, 11:19 | #43 (permalink) | |
04-09-2015, 11:20 | #44 (permalink) | |
Your Box is BLOCKLISTED. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-09-2015, 11:21 | #45 (permalink) | |
Please Activate your box 2 Times now. | |
