Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-10-2020, 16:44   #256 (permalink)
Member: 1703324
Thanks Meter: 2
Please Try Again Later (Server Busy)
Driver Version : 00021206
Library Version : 00030210
Box Type : ATF Nitro
Box Firmware : LogiCore 11.0.10
Software Version : v12.70
AdvanceBox SN : DAF51343EC9BD498B966AA26
Old 12-10-2020, 17:20   #257 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
Font size too small. For activation make font size bigger
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post:
Old 12-15-2020, 12:34   #258 (permalink)
Member: 2346218
Sonork: djawalak
Advance Turbo Flasher Found
Box Type : AdvanceBox Turbo
AdvanceBox SN : B7B95F50C89B42A8B58D0BEE
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
Old 01-18-2021, 22:05   #259 (permalink)
mondhert's Avatar
Member: 63299
Sonork: 100.1616476
Thanks Meter: 11
Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below:
AdvanceBox SN : F7C4A577850ADD09AF2A65D1
Old 01-19-2021, 05:04   #260 (permalink)
Member: 2917908
AdvanceBox Turbo
AdvanceBox SN : E2A927F98FDA54DDDFAEE8AF
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Please help me Atf team
thankoooooooooo
Old 01-19-2021, 08:45   #261 (permalink)
Member: 2601587
Thanks Meter: 201
Driver Version : 00020828
Library Version : 00030207
AdvanceBox SN : C2C2C07DBD745BFB89C585A7
Old 04-15-2021, 13:43   #262 (permalink)
Member: 1708219
Server down?
Please turn on server! Need Activate the box!
Old 04-21-2021, 10:02   #263 (permalink)
Member: 1050938
Sonork: no
AdvanceBox SN : 91900C21A54368AEF7B39E0C
Old 04-21-2021, 10:03   #264 (permalink)
Member: 1050938
Sonork: no
Old 04-25-2021, 17:07   #265 (permalink)
Member: 2104824
Thanks Meter: 28
Dear ATF product support, I still don't understand you, have we done anything wrong to you? why does everyone throw their customers halfway?
I have boxing on one computer working as it should, I need it to work on the main computer, cloning the full C drive did not help, are there solutions or can we forget about you?
The Following 2 Users Say Thank You to edik622 For This Useful Post:
Old 05-04-2021, 14:10   #266 (permalink)
Member: 2151773
Thanks Meter: 4
I cloned the entire disk and the box started with activation. Previous system work on RAID 0. After cloning process to regular SATA SSD everything is OK. I used HDClone from Miray Software - paid version.
The Following 2 Users Say Thank You to Sky-com For This Useful Post:
Old 05-15-2021, 09:16   #267 (permalink)
topline's Avatar
Member: 85139
Thanks Meter: 68
maestro,ci avete abbandonati !!
[QUOTE=Advance-Box;10832179]Before Posting Here about problems in Activating NEW or OLD ATF Boxes, Please follow Simple Steps Below:
1. Upgrade Your ATF Software to 11.90 which you can download here:
ATF_v11.90_Full_Installer.rar
2. Update Your Box Firmware to 11.0.10 via ATF 11.90 which you downloaded from Step 1.
3. Show Complete LOGS of Error Message
Moderators will AUTOMATICALLY DELETE POSTS if:
1. You are showing Logs from ATF Software which is LOWER than 11.90
2. You are showing Logs from ATF Firmware LOWER than 11.0.10
3. You are not showing COMPLETE LOGS
4. Your problem is NOT related to Box Activation
5. If you Blah Blah too much...
[/QUOTE
master, you have abandoned us !!
we bought the box and now it's dead, why don't you implement the box with a new huawei mtk, alcatel or other brand software?
if you do this we will all be grateful to you.
The Following User Says Thank You to topline For This Useful Post:
Old 06-23-2021, 14:49   #268 (permalink)
Member: 2690503
AdvanceBox SN : C9844955B6ECBF53AD6DF50F
SET BSI Load Done
Old 07-06-2021, 17:38   #269 (permalink)
Member: 1550235
Driver Version : 00021000
Software Version : v11.90
AdvanceBox SN : AA59E63FEB84C5D0D6BC862C
SET BSI Load Done
Old 07-13-2021, 11:27   #270 (permalink)
Member: 2108563
Thanks Meter: 19
AdvanceBox SN : EA38DD25E8701E8FB070D0F2
Page generated in 0.24577 seconds with 8 queries
