07-13-2021, 11:28 | #271 (permalink) |
Insane Poster Join Date: Jan 2014 Location: Indonesia
Member: 2108563 Status: Offline Thanks Meter: 19 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EA38DD25E8701E8FB070D0F2 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-13-2021, 11:31 | #272 (permalink) |
Member: 2108563 Status: Offline Thanks Meter: 19 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EA38DD25E8701E8FB070D0F2 ========================================= Please Try Again Later (Server Busy) |
07-26-2021, 13:01 | #273 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2346218 Status: Offline Sonork: djawalak Thanks Meter: 1 | Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B7B95F50C89B42A8B58D0BEE ========================================= Please Try Again Later (Server Busy) |
07-27-2021, 06:40 | #274 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | ATF box is now Dead Product i have a same Problem after installing a new windows Box Not active on my PC use ATF Old version ATF_v8.90_Full_Installer ****************************/file/obgac...aller.rar/file |
The Following 7 Users Say Thank You to .::Mustafa::. For This Useful Post: |
08-17-2021, 17:42 | #275 (permalink) |
Junior Member Join Date: Oct 2006 Location: Algeire/EL-oued Age: 38
Member: 363376 Status: Offline Sonork: 100.1620874 Thanks Meter: 1 | Please check the Activation of My Box. Logs Shown Below: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021234 Library Version : 00030216 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : A22B64AC9B8663A38842CE51 Box Status : NOT ACTIVATED |
10-14-2021, 20:06 | #276 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | i see the posts are fresh, so i have a problem too... ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B82C0AD4A2B1CCA2D0D001C2 BOX NOT ACTIVATED ;( |
The Following User Says Thank You to lampik For This Useful Post: |
11-22-2021, 20:15 | #277 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : A8E54466B43C002B88097E08 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
11-22-2021, 20:16 | #278 (permalink) |
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | atf box activation fail !! ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : A8E54466B43C002B88097E08 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to recan21 For This Useful Post: |
02-14-2022, 03:09 | #279 (permalink) |
Junior Member Join Date: May 2014
Member: 2189405 Status: Offline Thanks Meter: 0 | ATF not active ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : B58FF72AC3AB4853D958DC91 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ |
