03-16-2017, 04:37 | #196 (permalink) | |
Junior Member Join Date: Jun 2010 Location: Port-Au-Prince,Haiti
Member: 1326364 Status: Offline Sonork: 100.1646584 Thanks Meter: 2 | Atf software is activated on my pc Quote:
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FBC13F088B8742819BBDA9D2 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done | |
The Following 2 Users Say Thank You to cambymc For This Useful Post: |
03-16-2017, 09:26 | #197 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | Atf box activation problem solved 1: uninstal ATF Software 2: Delete ATF Folder From C Drive 3: Restart PC Again instal All ATF Software open exe; open Settings then General Setting and tick on Automatic Check for update close exe and again Launch ATF update on 12.67 Restar PC Problem Solved BR Qaiser Ali Khan |
04-02-2017, 00:12 | #198 (permalink) |
Junior Member Join Date: May 2016 Location: brasil
Member: 2574569 Status: Offline Sonork: sssss Thanks Meter: 1 | Donate money to this user help Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EF9416A8F298D2E4C29F979F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ delete host ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : EF9416A8F298D2E4C29F979F Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ |
The Following User Says Thank You to marcio-msa For This Useful Post: |
10-09-2017, 11:08 | #200 (permalink) |
Junior Member Join Date: Apr 2003 Location: Russia Age: 46
Member: 26169 Status: Offline Thanks Meter: 0 | Box not activated Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. Box worked all time. last 7 years. And I dont remember the name of reseller. Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : ACC336FD85349392EC934ABC How can I fix htis problem? |
11-08-2017, 05:25 | #201 (permalink) |
Junior Member Join Date: Jun 2011 Location: brunei darussalam
Member: 1596479 Status: Offline Thanks Meter: 2 | kindly please check my activation, thank you very much Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : A07E2B1BC83102E5F92C0A4B ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized |
11-08-2017, 05:27 | #202 (permalink) | |
Member: 1596479 Status: Offline Thanks Meter: 2 | Quote:
11-08-2017, 05:33 | #203 (permalink) | ||
solution: delete hosts file then activate again... Quote:
01-17-2018, 01:07 | #204 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1083489 Status: Offline Thanks Meter: 3 | please not activation Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : DAE28F2FD372241CF632B8CA ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ |
01-22-2018, 17:40 | #205 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2737101 Status: Offline Thanks Meter: 0 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : DF90288B96594717ADB5674F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software |
03-11-2018, 19:11 | #206 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2820071 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 8E8D2CCF88D98C8888294F81 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ can you help me with this problem ? |
04-02-2019, 15:41 | #207 (permalink) |
Freak Poster Join Date: Aug 2003 Location: pakistan Age: 47
Member: 36550 Status: Offline Sonork: 100.1605076 Thanks Meter: 7 | please check the activation of my atf box Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : A5F29619D5A211BDD033D936 ========================================= Please Try Again Later (Server Busy) |
04-03-2019, 06:58 | #208 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera imeipk
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : FD4B0C1C022BB95F0F348116 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
