05-29-2020, 12:39 | #241 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | sever down dead Product Quote:
sever down dead Product . BR, -=MR_Gsm=- | |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
06-04-2020, 14:14 | #244 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2629457 Status: Offline Thanks Meter: 2 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020416 Library Version : 00030118 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : EEEEC04CBB2DC6D18B3AB43A ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
06-06-2020, 03:07 | #245 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 189487 Status: Offline Thanks Meter: 30 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : D716FAECAE2A61B288678008 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software |
08-15-2020, 20:55 | #246 (permalink) |
Junior Member Join Date: Jul 2013 Age: 36
Member: 1983814 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : AC05300DCAC6CB8E83E2DD52 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software |
08-16-2020, 13:22 | #247 (permalink) |
Freak Poster Join Date: Feb 2019 Location: Haripur Thakurgaon Bangladesh
Member: 2894519 Status: Offline Sonork: 100.1673673 Thanks Meter: 34 | ATF BIG BOX PLEASE SOLVED IT ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : E391E87FA0CBAFADDBC412EB ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
08-18-2020, 05:32 | #248 (permalink) |
Major Poster Join Date: May 2011 Location: south africa
Member: 1585460 Status: Offline Sonork: 6678600 Thanks Meter: 3 | ATF activate Hi is only need to delete the host file They is the link https://www.google.com/url?sa=t&sour...I2enAZ8aV1_H2s Reply With Quote |
09-04-2020, 16:09 | #249 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Quote:
09-11-2020, 09:40 | #250 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2177146 Status: Offline Thanks Meter: 20 | how to active this box . I really need it.... http://uupload.ir/files/1n9w_2.png http://uupload.ir/files/j8qj_capture.png |
09-13-2020, 14:00 | #251 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Want understand that this BOX is DEAD PRODUCT? You are in DEAD PRODUCT SECTION, so WAKE UP and not spam more here!!! |
The Following User Says Thank You to allumts For This Useful Post: |
09-19-2020, 21:03 | #253 (permalink) |
Junior Member Join Date: Aug 2007
Member: 561134 Status: Offline Thanks Meter: 0 | Please Try Again Later (Server Busy) ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BCAF1ACB948829D29C278717 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
10-21-2020, 04:36 | #254 (permalink) |
Insane Poster Join Date: May 2012 Location: việt nam
Member: 1766019 Status: Offline Thanks Meter: 19 | Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 8B55F89F5D514F605D825783 ========================================= Please Try Again Later (Server Busy) ========================================= |
