04-09-2013, 07:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: vadodara
Member: 1849215 Status: Offline Thanks Meter: 136 | nokia 2610b after unlock no network.. <<< SOLVED >>> i had successfuly unlocked nokia 2610b RH-87 with ATF box ,but when i put sim card there is no network any solution sir and here is logs... MCU: V 07.04a 26-08-08 RH-87 (c) Nokia. IMEI: 011664007881725 Model : Nokia 2610 Product Serial Number: RDD421715 Product Code : 0567579 Module Code : 0203968 Basic Production Code: 0567073 PPM SW Version : V 07.04a 26-08-08 RH87 (c) Nokia. MCR MCU SW Version : V 07.04a 26-08-08 RH-87 (c) Nokia. HW Version : 6100 UEM Version : 1328 UPP Version : 12648 RFIC Version : 0500 DSP Version : P05w45.v49 LCD Version : ELBE Content Pack Version : Content: att 22-09-08 RH-87 (c) Nokia. ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 000000000003000B ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED MASTER_CODE : 5044122427 PHONE_MODE : TEST |
04-09-2013, 08:10 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @sunil1670 Because your phone 2610b RH-87 is using gsm frequency 850/1900 Mhz, and you need to convert it to 1800Mhz so that you can use it outside North America. Search forum on how to convert 2610b into 2610... B.R. |
