Booting/Flashing Failed... Please Try Again... need help plz evey mobile i am flashing gives me this error Booting/Flashing Failed... Please Try Again... |
post log here .........or screen shoot |
No logs = No help. And there is need to post this kind of threads. |
1 Attachment(s) Quote:
Where is the help i post the log |
bro try with fbus cabel |
Remove old ATF Setup Install Fresh ATF 8.00 and update EXE to 8.10 afterwards Update IMPORTANT FILES from Product Support tab Install latest Nokia USB drivers from here: C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1 .45.0.msi When all done, open atf software and do flash again. It should be okay... How to post logs on forum: right click on ATF Screen where are all "LOGS" copy all paste here and add CODE TAG .. BR |
Brother This is always happen with ATF v10.0, I have tried many time and get the same error. But lower version do well (I used v7.90 to flash E7-00 RM-626)... Regards seanna |
I need to see full log, will you please post it here? BR |
need perfect sollution error error 16 program error bb5 fbus flashing 10.11 latest verson i tried many times update firmware,uninstall and reinstall driver,update important file, box firmware update , restore box firmware same problem but atf 8.70 all ok no problem why latest verson create the problem 16 program error bb5 fbus flashing and usb also booting/flashing failed, need perfect sollution atf team |
error 16 program error bb5 fbus flashing 10.11 latest verson i tried many times update firmware,uninstall and reinstall driver,update important file, box firmware update , restore box firmware same problem but atf 8.70 all ok no problem why latest verson create the problem 16 program error bb5 fbus flashing and usb also booting/flashing failed, need perfect sollution atf team Report Post Reply With Quote |
ATF team chalenge sanjib121 is absalutly right ihav also tried thease all instructions e.g change the opperating system of my pc.then change hole pc. chang atf box.changed usb cables.change nokia conectivity cable drivers . change flashing files. but but but same problem. only salution is v 8.00 or lower then ok. pls ATF team why atf box occures this problem in latest exe thanks regards |
