box have h/w probelm need help ox is heating to much - [Problem Solved] box have h/w probelm need help box is heating to much 1st it have heating and green led both problems i follow the green led solution now green led is ok but phon still not boot and pcb of box is still heating to much :confused::confused::confused: |
i think its caused by output regulator ic or filter check out put voltage and path it will help you shore |
can u be more spesific all 3 led of my box r active when i startt boot cheq but allways boot faild and 2big coils r heating in by box behind external fleshing port (1202 fleshing port ) |
thx. to boss advance-box box is ok now and working good again |
AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 05F0000E ID DWORD 1 : 00136B56 ID DWORD 2 : 9E3D37BE ID DWORD 3 : 550B724E ID DWORD 4 : 640B1262 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 65 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 22FE -> K8S5615ETA Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 0A SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :22FE ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 00EC Device ID : 22FE Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ============================================ OLD Protocol Detected... Using Turbo Mode... ============================================ Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= FlashInfo.RestartMode : 2 MCU: V 05.00 27-04-07 RM-217 (c) Nokia. IMEI: 356437017639562 Model : Nokia 6300 Product Serial Number: DEF975028 Product Code : 0546425 Module Code : 0203166 Basic Production Code: 0537040 MCU SW Version : V 05.00 27-04-07 RM-217 (c) Nokia. O BT MCM Version : 06cc-P9.1 PPM Version : V 05.00 27-04-07 RM-217 (c) Nokia. HW Version : 1002 RFIC Version : 17211721 DSP Version : pb06w14v51 Content Pack Version : Content: ora_uk_v2 V 05.00 27-04-07 RM-217 (c) Nokia. AHNE Version : 11 Retu Version : 32 Tahvo Version : 53 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL1/PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 00071 PHONE_MODE : TEST MODE |
