06-12-2012, 17:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1085379 Status: Offline Thanks Meter: 65 | Lumia 800 become dead while flashing Need help atf team to recover this device |
06-13-2012, 07:10 | #4 (permalink) |
Member: 1085379 Status: Offline Thanks Meter: 65 | Here is the log 11:00:30 : Basic Phone Information 11:00:30 : ================================================ 11:00:30 : SW Version : 1600.2475.7720.11414 11:00:30 : IMEI Plain : 359289040685105 11:00:31 : HW Version : 112.1402.2.3 11:00:31 : Product Code : 059L7C2 11:00:32 : Basic Product Code: 059J2N6 11:00:32 : Module Code : 0205051 11:00:32 : PSN Number : 001ADFBAB 11:00:33 : NCSD Version : 1.5 11:00:33 : 11:00:33 : ================================================ 11:00:33 : Extended Phone Information 11:00:33 : ================================================ 11:00:33 : Public ID : D3C64C32132140EE027BD245AD30E9AA 11:00:33 : Wireless Lan ID: 14:36:05:39:34:7F:00:00 11:00:34 : Bluetooth ID : 14:36:05:39:0D:6F:00:00:00:00:00:00 11:00:34 : 11:00:43 : Rebooting to OSBL MODE 11:01:45 : 11:01:45 : ================================================== ==== 11:01:45 : ERROR: Active Phone Handle was NOT DETECTED 11:01:45 : ================================================== ==== 11:01:45 : 11:01:45 : 11:01:45 : ================================================== ==== 11:02:11 : Windows Phone Flashing Started 11:02:11 : 11:02:11 : OSBL File Found: 11:02:11 : RM801_11w50_1_prod_generic_nokia_osbl.esco 11:02:11 : AMSS File Found: 11:02:11 : RM801_11w50_1_prod_generic_amss.esco 11:02:11 : ADSP File Found: 11:02:11 : RM801_11w50_1_prod_generic_adsp.esco 11:02:13 : WPOS File Found: 11:02:13 : RM801_11501_prod_394_02_boot.esco 11:02:13 : USER AREA ERASE File Found: 11:02:13 : RM801_11w50_1_prod_generic_user_area_erase.esco 11:02:13 : 11:02:13 : ================================================== ==== 11:02:13 : Windows Phone Lumia Flasher 11:02:13 : ================================================== ==== 11:02:13 : 11:02:13 : If the Phone is ALIVE 11:02:13 : 1. Power On the Phone and Connect it to the USB Port 11:02:13 : 11:02:13 : If the Phone is DEAD 11:02:13 : 1. Press and Hold the VOLUME UP button 11:02:13 : 2. Connect it to the USB Port while still Pressing 11:02:13 : the VOLUME UP button 11:02:13 : 3. Continue to Press the VOLUME UP button for 8 more 11:02:13 : seconds 11:02:13 : ================================================== ==== 11:02:13 : 11:02:23 : ERROR: Incorrect Device Mode Detected !!! 11:02:23 : 11:02:23 : Make sure you are Pressing and Holding 11:02:23 : the VOLUME UP Button on the Phone... 11:02:23 : 11:02:23 : Please Try Again... 11:02:23 : Operation Cancelled... |
The Following User Says Thank You to coolmfarshard For This Useful Post: |
06-13-2012, 07:25 | #5 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | This log says that the box didn't start the flash or didn't finished the flash job. So try use other cable and start again. And you say Become dead, if you read the Log you will know what happened the box couldn't flash the phone because: 11:02:13 : Windows Phone Lumia Flasher 11:02:13 : ================================================== ==== 11:02:13 : 11:02:13 : If the Phone is ALIVE 11:02:13 : 1. Power On the Phone and Connect it to the USB Port 11:02:13 : 11:02:13 : If the Phone is DEAD 11:02:13 : 1. Press and Hold the VOLUME UP button 11:02:13 : 2. Connect it to the USB Port while still Pressing 11:02:13 : the VOLUME UP button 11:02:13 : 3. Continue to Press the VOLUME UP button for 8 more 11:02:13 : seconds 11:02:13 : ================================================== ==== 11:02:13 : 11:02:23 : ERROR: Incorrect Device Mode Detected !!! 11:02:23 : 11:02:23 : Make sure you are Pressing and Holding 11:02:23 : the VOLUME UP Button on the Phone... 11:02:23 : 11:02:23 : Please Try Again... 11:02:23 : Operation Cancelled... |
06-14-2012, 04:08 | #6 (permalink) |
Member: 1085379 Status: Offline Thanks Meter: 65 | Flashing didn't start but there is driver pop up and ask for format, so i format after that device become dead as i know i format the memory chip. Is there any way to recovery this device. |
08-28-2013, 10:44 | #7 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1917663 Status: Offline Sonork: 100.1635884 Thanks Meter: 0 | lumia 800 i have flashing lumia 800 via atf and device give error and ask and driver for format i format and device got dead now not even detecting by windows Need help atf team to recover this device. help plez? |
08-28-2013, 11:50 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @junaid khawaja Your phone is dead and you need to Dead Boot Repair it via Test Point. ATF Can do this, you can see TP Pictures here: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX ATF did not ask you to format your phone,,, Windows did. And if you make a little research, many people have been killing phones because of formatting that drive. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
08-29-2013, 13:34 | #10 (permalink) |
Member: 1917663 Status: Offline Sonork: 100.1635884 Thanks Meter: 0 | boot repair o.k ofter flashing this eror Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED plz help |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
