Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-02-2014, 05:03   #1 (permalink)
Member: 525940
Thanks Meter: 213
lumia 520 always not compatible on flash file - (SOLVED)
lumia 520 always not compatible on flash file even do i use 3 firmware and the last one that i flash is same product code of the phone which is i get from sticker of the phone
history of the phone is dead boot
it was revive via atf jtag and the phone now is hang up on nokia with red background
now i try to reflash the phone but it always end up with this
This Flash File is NOT COMPATIBLE with this Phone
Windows Phone 8 Flashing Started
Loading Flash Files Please Wait...
Windows Phone 8 Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Connect Phone to the USB Port
2. Press and Hold the VOLUME DOWN and POWER Buttons
3. Wait until the Phone Vibrates Shortly...
4. Stop Pressing the Buttons...
Nokia Phone Info Mode Initiated...
Please wait upto 15 Seconds for SW Reset
Version: 1.1.1.3
Product Code: 059T4C0
Module Code: 0205435
Continuing Previous Boot...
Please wait upto 30 Seconds for Boot Re-entry
Boot Flash Mode Successful...
Buffers Flushed OK...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E90000
Block ID 0x05 : Nokia.MSM8227.P6036.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100030000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode : SYNC + ASYNC
Query Flash App Information...
Flash App Information: 02010C011700
UEFI App: FLASH APP
Flash App Protocol Version: 1.12
Flash App Implementation Version: 1.23
Query ROOT KEY HASH...
ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
Sending Image Signatures...
ERROR: Flash Signature Block REJECTED!
This Flash File is NOT COMPATIBLE with this Phone.
ERROR: Flashing Failed!
Old 08-02-2014, 05:20   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Did you use BIG Boot file to fix the phone via JTAG?
Old 08-02-2014, 06:43   #3 (permalink)
Member: 525940
Thanks Meter: 213
i use 520_RM-914_FULL_BOOT.afp
can you give me link for tested firmware?
thanks
Old 08-02-2014, 08:25   #4 (permalink)
Member: 525940
Thanks Meter: 213
i got error writing big boot
Default language ID 0x0409
JTAG Interface Connected, S/N 0xCC8BAE33
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 1, compiled 7/25/2013 8:28:00 AM
Phone Type : Lumia 520 RM-914
CPU Type : Qualcomm MSM8227
Storage TYpe: eMMC 8GB
Boot Package: 1030.6409.1314.1006 (Quick Fix)
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Restore Boot...
Waiting for Device Connection 15 second(s)...User break!
JTAG Interface Disconnected!
AFP revision 4, compiled 6/25/2014 10:41:00 PM
Storage Type: eMMC 8GB
Boot Package: 3056.40000.1408.0007 (BIG BOOT)
Restore Boot...
Waiting for Device Connection 15 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting EMMC #1 ID...Toshiba 008G92, 7.28 GiB
Partition Config: Boot from USER, Boot ACK OFF (0x38)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (3240 Op/Sec)
Restoring MBR Data...OK
Restoring GPT Data from AFP...OK
Restoring Partition #1...OK
Restoring Partition #2...OK
Restoring Partition #3...Flash Write Error at 0x01548000, DCC Read Error, Timeout During Operation!
Restore Boot...
Halting Core...OK
Sending Flash Loader...OK (3241 Op/Sec)
Restoring Partition #1...Flash Write Error at 0x010F0000, DCC Read Error, Timeout During Operation!
Task Process Saved to: LUMIA_520_RM-914_BIG_BOOT.task
Restore Boot...
Halting Core...Shift IR Error(s)
Restore Boot...
Halting Core...OK
Restoring Partition #3...OK
Restoring Partition #4...OK
Restoring Partition #5...OK
Restoring Partition #6...OK
Restoring Partition #7...OK
Restoring Partition #8...OK
Restoring Partition #9...OK
Restoring Partition #10...Flash Write Error at 0x0D5B0000, DCC Write Error, Timeout During Operation!
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x4F1F0F0F IR4
Restore Boot...
Halting Core...OK
Restoring Partition #10...Flash Write Error at 0x0D5B0000, DCC Write Error, USB Write Error, Written 0x00000000 of 0x0000D045
got this error 2 times
Old 08-02-2014, 08:48   #5 (permalink)
Member: 525940
Thanks Meter: 213
i got those error but when i try to reflash it on atf and now it accept the flash files and phone is alive
Version: 1.1.1.3
Block ID 0x10 : 0100130000
Secure FFU Mode :
Flash App Information: 02010F011C00
UEFI App: FLASH APP
Flash App Protocol Version: 1.15
Flash App Implementation Version: 1.28
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
Finished Sending all DATA BLOCKS!
Exiting FLASH Mode via REBOOT...
Exit FLASH Mode Successful!
Flashing Done!
Total Flashing Time : 00:02:27
Old 08-02-2014, 09:24   #6 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
working okkkkkkkkkkkk...........
Old 10-25-2015, 07:58   #7 (permalink)
Member: 2273768
Sonork: phamduongnhat
solution ok, thanks all
Page generated in 0.20621 seconds with 8 queries
