Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-06-2010, 17:10   #1 (permalink)
Member: 936609
Thanks Meter: 5
Can ATF fix 2700c got problem "pasubtoc does not exist" then it can not flashing
I have NK 2700c first I can check and read file pm 308 by HWK,then I flash it with version 9.97 it suddendly stops .then I check it it inform "pasubtoc does not exist"rebooting mobile .I check on my computer ,it has this pasubtoc file at program files\ phoenix \how can I fix my phone ,it dies now,how can I deal with this problem?help me thank!
Old 11-06-2010, 20:29   #2 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
try to flash with fbus cable and post logs about what error you got while flashing this phone
Old 11-07-2010, 09:56   #3 (permalink)
Member: 936609
Thanks Meter: 5
try to flash with fbus cable and post logs about what error you got while flashing this phone.this is its log when I check:1ST BOOT : C0,07 [Rm-561] [2.1.0.1]
RAPx ID : 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx PBID : 1DB001165FA28C56C92E77F2176CA54B03317C8A
RAPx MODE : 00
RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
PASUBTOC not Exists
Rebooting Mobile
And then its log when I Flash =hwk Fbus cable:
EM 1 ID : 00000296
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm561__09.97.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 00:09
DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable !
DATA_BLK_ERROR at: 0x00000400, 03
ERR: CMT FLASH WRITE D_BLK C7012D0103CD000090000000F172, LN: 0x0000A0, Time: 02:01
Process Failed, Repowering Mobile
ATF TEAM HELP ME TO RESOLVE it ,thanks a lot
Old 11-07-2010, 15:48   #4 (permalink)
Member: 936609
Thanks Meter: 5
MR YAVAJOHN do you think ATF can fix 2700c ?I will get it to fix or I have to reball flash IC ,GIVE ma your ideas ,thank!
Old 11-08-2010, 10:16   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hello!
PASUBTOC does not exist - means phone is stopped during MCU ERASE - there's no need to reball ICs, just make flash again with FBUS cable. Put some rubber bands on cable to be fitted well on phone pcb.
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 11-08-2010, 15:39   #6 (permalink)
Member: 936609
Thanks Meter: 5
I flashed it many times and use many boxes :2xHWK,JAF,CYCLOBOX, 4 computers and 02 multicable and hwk cable to flash it but it still has its disease .do I need ATF BOX to flash it or U have an other solution to help me !thank!
Old 11-09-2010, 07:03   #7 (permalink)
Member: 888099
Thanks Meter: 33
incase of pasubtoc error. some times i finished flashing with atf, in this case other box always show error on pasubtoc. but sometime you need to rehoot flash ic brother
Old 11-09-2010, 10:14   #8 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
If you got ATF box, than post flashing logs of it, we can't help about other products.
Old 11-09-2010, 15:04   #9 (permalink)
Member: 936609
Thanks Meter: 5
You should wait for me several days I have to get ATF at SAIGON CAPITAL OF SOUTH VIETNAM and then post flashing logs of it to you should keep your promise ,THANK!
Old 11-09-2010, 15:09   #10 (permalink)
Member: 936609
Thanks Meter: 5
I appreciate your good idea !thank!
Old 11-16-2010, 16:17   #11 (permalink)
Member: 936609
Thanks Meter: 5
I 've just got it and then I show it lod for you to help me solve this problem thank!:
    VBATT OFF...
VBATT ON
Setting VBATT Done!...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 72351368  (0x88) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 030C1921
     ID DWORD    4 : 01033000
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  ROM_ID 15
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 1DB00116
     ID DWORD    1 : 5FA28C56
     ID DWORD    2 : C92E77F2
     ID DWORD    3 : 176CA54B
     ID DWORD    4 : 03317C8A
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           D1
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 03
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0089 ->
   Device ID         : 8982 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 8A31
 2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
   Block Length      : 13
   Device Index      : 00
   Device Contents   : FFFFFFFFFFFFFFFFFFFF
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 Checksum   : 61
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
 RAP3Gv3_algo.fg
First Algo byte : C0
Flash Descriptor
   Device ID         : 8982
   Revision ID       : 0000
   Size              : 04000000 (64 MB)
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 64
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO : VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType  : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
 No PAPUBKeysHash Returned
Scanning Simlock Type...
 Simlock Type is UNKNOWN...
Forcing Test Mode via BUSCHECK...
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
                  TIME STARTS HERE
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 72351144  (0xA8) bytes returned
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           D1
 MessageID  : C1
 SubBlocks  : 03
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 8A31
   Block Length      : 13
   Device Index      : 00
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
 Checksum   : 61
SendAlgoCode_DCT5..
 RAP3Gv3_algo.fg
Flash Descriptor
   Device ID         : 8982
   Revision ID       : 0000
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 64
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Pabub KEY Request
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
ERROR : PHONE READ INFO FAILED
Use "BUSCHECK" Button to Force the Phone
into Local Mode... Then "SCANPHONE" after.
For N95, N95-8GB and E90 Phones, you need a
Test Mode Adapter to provide some Extra Power
so that the Phone will go into Local Mode...
Old 11-17-2010, 03:57   #12 (permalink)
Member: 936609
Thanks Meter: 5
Mr Angel help me to resolve it as you told me thank!
Old 11-17-2010, 06:24   #13 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
Delete this three loaders and try again flashing.
http://forum.gsmhosting.com/vbb/f609...-00-a-1140431/
Old 11-17-2010, 15:47   #14 (permalink)
Member: 936609
Thanks Meter: 5
I will do it and I let you know if I have my success .Thank!
Old 11-18-2010, 19:03   #15 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@quoccongtg
Flash the phone... You cannot "Scan Phone" on a dead phone (which your logs show)
This means phone has corrupted firmware or no firmware inside...
Go to ATF Support Site and get the latest 2700c Flash file (version 9.98)
Show your logs after if still have problem.
B/R
X
The Following User Says Thank You to Advance-Box For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.32124 seconds with 9 queries
