Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-03-2014, 09:16   #1 (permalink)
Member: 962014
Thanks Meter: 7
Can I Jtag nokia xl - (SOLUTION INSIDE - GET NEW AFP for NOKIA XL)
hi
i cant find AFP BOOT FILES for Nokia XL
my device dead ! pls upload nokia XL AFp files
The Following User Says Thank You to gandolf007 For This Useful Post:
Old 06-03-2014, 13:05   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,110
Originally Posted by gandolf007 View Post
hi
Hi,
It is here in 4shared folder
NOKIA_XL_RM-1030_FULL_BOOT_1.1.0.6 - Download - 4shared - Linus Hernandez
l will upload it to ATFJ server later... for now download from link above.
B.R.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 06-03-2014, 13:20   #3 (permalink)
Member: 651945
Now Also available via the ATFJ Server....
Click ---> Help ---> Updates ----> Check Updates
you will find it there.
B.R.
Old 06-03-2014, 13:43   #4 (permalink)
Member: 962014
Thanks Meter: 7
tanx alot dear
is suport nokia xl ver 1.1.2.20 ?
Old 06-03-2014, 13:49   #5 (permalink)
Member: 651945
@gandolf007
This version 1.1.2.20 is for REVISION 2 phones only.
It will not work on non REVISION 2 phones, since boot is different.
If your Phone's Product Code is not in list below, it means your phone is NOT REVISION 2 and this firmware is NOT COMPATIBLE with your phone.
059W161: RM-1030 NDT APAC ID ERA V2
059W162: RM-1030 NDT APAC ID PAR V2
059W163: RM-1030 NDT APAC ID TRI V2
059W159: RM-1030 NDT APAC KH V2
059W160: RM-1030 NDT APAC MY V2
059W158: RM-1030 NDT APAC PH V2
059W157: RM-1030 NDT APAC TH V2
059W156: RM-1030 NDT APAC VN V2
059W168: RM-1030 NDT EURO KZ V2
059W166: RM-1030 NDT EURO PL V2
059W164: RM-1030 NDT EURO RU V2
059W165: RM-1030 NDT EURO TR V2
059W167: RM-1030 NDT EURO UA V2
059W180: RM-1030 NDT IMEA AE V2
059W181: RM-1030 NDT IMEA BD V2
059W173: RM-1030 NDT IMEA EG V2
059W171: RM-1030 NDT IMEA IN V2
059W174: RM-1030 NDT IMEA KE V2
059W179: RM-1030 NDT IMEA KW V2
059W175: RM-1030 NDT IMEA NG V2
059W177: RM-1030 NDT IMEA OM V2
059W170: RM-1030 NDT IMEA PK V2
059W178: RM-1030 NDT IMEA QA V2
059W176: RM-1030 NDT IMEA SA V2
If you badly need to use 1.1.2.20 on a NON REVISION 2 Phone, then UNCHECK 7 BOOT Partitions before clicking the FLASH Button in ATF Software...:
xxxxxxx_emmc_appsboot.mbn
xxxxxxx_emmc_appsboothd.mbn
xxxxxxx_oemsblhd.mbn
xxxxxxx_oemsbl.mbn
xxxxxxx_qcsblhd_cfgdata.mbn
xxxxxxx_qcsbl.mbn
xxxxxxx_fat.bin
Then you can flash the firmware to your phone.
Post Results after you have fixed your Phone.
B.R.
Old 06-09-2014, 09:44   #6 (permalink)
Member: 962014
Thanks Meter: 7
problem with j tag nokia xl
i downloaded NOKIA_XL_RM-1030_FULL_BOOT_1.1.0.6 afp files and when i push restore button ، say below error in picture !!
jtag chain is ok !
qualcomm cdma technologies msm drivers is installed!
whats problem ?
Old 06-09-2014, 13:48   #7 (permalink)
Member: 651945
@gandolf007
1. Do not connect battery
2. Only use USB Connection
3. Make sure the 2 ORANGE pads are connected properly.
B.R.
Old 06-09-2014, 15:22   #8 (permalink)
Member: 651945
Hi,
Please Download the FIXED AFP file for working with latest ATF EXE.
(Original Nokia XL AFP was not compatible with latest EXE)
So here, you will see it...
Here is my Test Result on latest AFP and latest EXE build 4551...
Here is my wired Test Phone...
B.R.
The Following 4 Users Say Thank You to Advance-Box For This Useful Post:
Old 06-10-2014, 09:33   #9 (permalink)
Member: 962014
Thanks Meter: 7
problem Solved
tanx advance-box
but i flash another device without boot file and device dead !!
reason ?
Old 06-10-2014, 09:35   #10 (permalink)
Member: 962014
Thanks Meter: 7
problem with flash nokia x and xl
problem Solved
tanx advance-box
reason ?
Old 06-10-2014, 10:47   #11 (permalink)
Member: 651945
problem Solved
tanx advance-box
reason ?
Because you are trying to flash V2 firmware to your NON V2 Phone.
I already explained that this will KILL your phone.
If you really want to flash V2 firmware, then the safest way is to just flash the KERNEL (SYSTEM) partition.
For your dead phone, for full recovery follow steps:
1. Repair Boot via JTAG
* I uploaded 1.1.1.0 and 1.1.1.4 boots for RM-1030 to ATFJ Server already so you can use them if you like
2. Flash phone via USB Recovery with Firmware Version preferably same as Boot Version used when you repaired via JTAG.
3. Phone should be 100% working now...
If you want to flash V2 firmware at this point, then
4. Flash V2 Firmware SYSTEM Partition Only.
Phone will be working and with latest kernel inside...
But you know, in reality 1.1.1.4 is newer than 1.1.2.20
So better use 1.1.1.4 instead and skip step 4 above
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 06-29-2014, 19:49   #12 (permalink)
Member: 2213792
hi
What difference nokia xl and nokia xl V2 in hardware&saftware?
Old 06-30-2014, 02:59   #13 (permalink)
Member: 651945
@wow2005dlta
They are using different bootloaders.
Other things are almost exactly the same.
Old 07-29-2014, 15:20   #14 (permalink)
papsnew's Avatar
Member: 390521
Thanks Meter: 54
@ Advance-Box
please share the test points to use(for RM-1030) nokiaXL.. i saw in your earlier post you said they resemble that for 510..RIGHT?..i find it easy to use molex ( i intend to use molex)
Old 07-29-2014, 15:41   #15 (permalink)
Member: 651945
@papsnew
No, it is not "molex".
Just load AFP file to ATFJ.exe and you will see pinouts.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.18084 seconds with 7 queries
