04-11-2011, 07:18 | #1 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Love Electronics Age: 37
Member: 665757 Status: Offline Sonork: 100.1606890 Thanks Meter: 15 | e71 camera not working IMEI: 351940032378350 Model : Nokia E71 Product Serial Number: MMI977738 Product Code : 0566234 Basic Production Code: 0557205 Default SN Type : 0 PPM Version : V ICPR71_08w44.2 19-11-08 RM-346 (c) Nokia HW Version : 0910 RFIC Version : 17141715 DSP Version : leevi_ICPR71_08w41 AHNE Version : 11 APE SW Core Version : 200.21.118 APE Variant Version : 200.21.118200.21.118_v27 APE Test Version : RM346ENO7411718214.N32 Retu Version : 15 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE camera configuration not showing i have changed camera ,write pm, but camera on black screen box not showing camera configuration read & write dcc option not highlight plz help Last edited by tarunbhatia; 04-11-2011 at 07:26. |
04-11-2011, 07:32 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | @tarunbhatia Download this: http://174.120.45.27/tmp/E71_RM-346_DCC.rar Inside you have 3 PM Files for E71 RM-346 DCC... Try to write them 1 at a time, and check if camera is fixed by one of them. Choose only 1 PM file at a time... After you write it, then check phone status. If phone is still not OK, then try another PM file... etc... etc... Also, I would strongly suggest you flash your firmware to the LATEST E71 RM-346 version which is 410.21.010... Before you flash update, remember to BACKUP RPL and BACKUP FULL PM. B.R. |
04-11-2011, 12:07 | #3 (permalink) |
Member: 665757 Status: Offline Sonork: 100.1606890 Thanks Meter: 15 | dear sir i said write dcc or read dcc options does not highlighting in my software when i scan the phone in end dcc configuration not showing of any phone plz give me any solution i have removed my atf setup and reinstall it same problem |
04-11-2011, 12:12 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
If SCAN phone DOES NOT show DCC version info - than maybe it is Hardware problem. BUT, first try to write DCC files like we write PM - Write PM option, after power up phone and check, if not work, try other DCC version. BR | |
04-11-2011, 12:23 | #5 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,119 | Quote:
Bro, did you check the files I uploaded to you? They are PM files... They are not DCC files... So please download it and give it a try. Just write PM. B.R. | |
10-25-2011, 03:33 | #9 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Russia Age: 44
Member: 1331464 Status: Offline Thanks Meter: 206 | Hallo Advance Box team. You are not right. This is software problem. Camera config is on .fpl file. This config not present in pm if you have pm backup. I fixed this problem by flashing craked phoenix. After tis camera work good. No one box cant fix this now. Please try erase e71 phone and write all backups. You will see not work camera and box will not found camera problems. |
10-27-2011, 05:12 | #10 (permalink) |
Member: 1331464 Status: Offline Thanks Meter: 206 | More for problem. At last update saw that team tried to fix this problem. At the end of scan atf found 2 dcc files and write it. Than scan again and try write file again. And this continue only manual. After both files camera still not work. Pls team see this problem again and fix it |
11-08-2011, 12:46 | #14 (permalink) |
Member: 1331464 Status: Offline Thanks Meter: 206 | Up theme. Problems in all boxes with this phone after erase. But only atf team begin work with this problem. Please atf tem fix it. You begin do it and thinking you finish it first. Problem present because this phone after software death dont give local mode after flash. Only full erase with npc backup help fix it. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
wintesla doesnt work | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 14:51 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
