02-17-2014, 12:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: rajasthan
Member: 597610 Status: Offline Thanks Meter: 50 | nokia lumia 610 custom file write error ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 11010030303847344200D4CD49EC CSD : D00E00320F5903FFFFFFFFE79640001F eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 610/610C Detected eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 008G4B Product Rev : 0.0 Product SN : D4CD49EC Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO ok but custom file write error show R1b timeout error which problem help me |
02-24-2014, 18:56 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: colombia
Member: 576776 Status: Offline Thanks Meter: 133 | hi bro, i have same problem with model 505 rm923 write file DLOAD file for Lumia 505 - RM 923,this error write with file, i have 5 nokia lumia 505 for repair. |
