03-12-2011, 07:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india-gujrat-nadiad
Member: 384984 Status: Offline Thanks Meter: 456 | i can't unlock bb5 sl 2 phone ?? hear is log & image MCU: V 04.90 22-08-08 RM-414 (c) Nokia IMEI: 351954033798904 Model : Nokia 6600 slide Product Serial Number: KNI433783 Product Code : 0572228 Module Code : 0203776 Basic Production Code: 0558090 Default SN Type : 0 MCU SW Version : V 04.90 22-08-08 RM-414 (c) Nokia CTM BT MCM Version : 2222-sm143B PPM Version : V 04.90 22-08-08 RM-414 (c) Nokia HW Version : 2001 RFIC Version : 17141715 DSP Version : ICPR72_vs08w30 LCD Version : SHARP Content Pack Version : Content: tmo_gb V 04.90 22-08-08 RM-414 (c) Nokia AHNE Version : 30 Retu Version : 15 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider : T-Mobile-One 2 One;United Kingdom Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 08B00003 ID DWORD 1 : 6A607D56 ID DWORD 2 : E20A84AB ID DWORD 3 : EEC71038 ID DWORD 4 : EDF1FE7F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum DC SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 003F -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : B5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :003F ExtID :0000 RevID :8A21 Flash Descriptor Manufacturer Code : 0001 Device ID : 003F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A4B03CEB0AC8A915C4ECE9894BC44D6CE68F3AA4 START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\351954033798904\3519540337989 04_101946.rpl FlashInfo.RestartMode : 2 MCU: V 04.90 22-08-08 RM-414 (c) Nokia IMEI: 351954033798904 Model : Nokia 6600 slide Product Serial Number: KNI433783 Product Code : 0572228 Module Code : 0203776 Basic Production Code: 0558090 Default SN Type : 0 MCU SW Version : V 04.90 22-08-08 RM-414 (c) Nokia CTM PPM Version : V 04.90 22-08-08 RM-414 (c) Nokia HW Version : 2001 RFIC Version : 17141715 DSP Version : ICPR72_vs08w30 LCD Version : SHARP Content Pack Version : Content: tmo_gb V 04.90 22-08-08 RM-414 (c) Nokia AHNE Version : 30 Retu Version : 15 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider : T-Mobile-One 2 One;United Kingdom Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE Changing MODE : FLASH BOOTING BB5 Phone... ************************************************** **** TIME STARTS HERE ************************************************** **** CMT Hardware : 030C192101023000 CMT PUBLIC ID : 08B000036A607D56E20A84ABEEC71038EDF1FE7F CMT ROOTHASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM_ID : 273F6D55DFAAF68F Send Loader... Custom Loader Running! Restarting phone, please wait .. . VBATT OFF... VBATT ON Setting VBATT Done!... Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s MCU: V 04.90 22-08-08 RM-414 (c) Nokia IMEI: 351954033798904 Model : Nokia 6600 slide Product Serial Number: KNI433783 Product Code : 0572228 Module Code : 0203776 Basic Production Code: 0558090 Default SN Type : 0 MCU SW Version : V 04.90 22-08-08 RM-414 (c) Nokia CTM BT MCM Version : 2222-sm143B PPM Version : V 04.90 22-08-08 RM-414 (c) Nokia HW Version : 2001 RFIC Version : 17141715 DSP Version : ICPR72_vs08w30 LCD Version : SHARP Content Pack Version : Content: tmo_gb V 04.90 22-08-08 RM-414 (c) Nokia AHNE Version : 30 Retu Version : 15 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider : T-Mobile-One 2 One;United Kingdom Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : LOCAL MODE Connecting to Server... Connection GOOD! Sending data to server... Warning : Main Socket server not responding |
03-12-2011, 09:02 | #5 (permalink) |
Member: 384984 Status: Offline Thanks Meter: 456 | thenks brother it done with offline method hear is log MCU: V 07.01 21-08-08 RM-237 (c) Nokia. IMEI: 359343022222195 Model : Nokia 3110c Product Serial Number: 7F0821634 Product Code : 0514950 Module Code : 0203291 Basic Production Code: 0542523 MCU SW Version : V 07.01 21-08-08 RM-237 (c) Nokia. MR BT MCM Version : 06cc-P9.1 PPM Version : V 07.01 21-08-08 RM-237 (c) Nokia. HW Version : 2000 RFIC Version : 17211721 DSP Version : ICPR61_08w10 Content Pack Version : Content: mr V 07.01 21-08-08 RM-237 (c) Nokia. AHNE Version : 11 Retu Version : 32 Tahvo Version : 53 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE Unlocking Done.... =========================================== Operation time started : 11:59:31 PM Operation time End : 12:00:33 AM =========================================== |
02-24-2014, 21:45 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: algeria
Member: 228703 Status: Offline Thanks Meter: 21 | cant unlock bb5 sl2 6600s Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13300016 ID DWORD 1 : 0B877D56 ID DWORD 2 : E4E34D40 ID DWORD 3 : 7EB41B29 ID DWORD 4 : DE36F848 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum CB SearchForBootstrap_DCT5.. C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ============================================ OLD Protocol Detected... Using Turbo Mode... ============================================ PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A4B03CEB0AC8A915C4ECE9894BC44D6CE68F3AA4 =========================================== PHONE FIRMWARE VERSION: V 05.23 29-10-08 RM-414 (c) Nokia =========================================== Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 7 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13300016 ID DWORD 1 : 0B877D56 ID DWORD 2 : E4E34D40 ID DWORD 3 : 7EB41B29 ID DWORD 4 : DE36F848 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum CB SearchForBootstrap_DCT5.. C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) 8-BIT PROTOCOL ERROR: Phone did not Ack !!! ERROR: Sending Loader Failed... ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BOOTING BB5 Phone... ************************************************** **** TIME STARTS HERE ************************************************** **** CMT Hardware : 030C192101023000 CMT PUBLIC ID : 133000160B877D56E4E34D407EB41B29DE36F848 CMT ROOTHASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM_ID : 273F6D55DFAAF68F Send Loader... 8-BIT PROTOCOL ERROR: Phone did not Ack !!! Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 7 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13300016 ID DWORD 1 : 0B877D56 ID DWORD 2 : E4E34D40 ID DWORD 3 : 7EB41B29 ID DWORD 4 : DE36F848 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum CB SearchForBootstrap_DCT5.. C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BOOTING BB5 Phone... ************************************************** **** TIME STARTS HERE ************************************************** **** CMT Hardware : 030C192101023000 CMT PUBLIC ID : 133000160B877D56E4E34D407EB41B29DE36F848 CMT ROOTHASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM_ID : 273F6D55DFAAF68F Send Loader... Custom Loader Running! Restarting phone, please wait .. . VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13300016 ID DWORD 1 : 0B877D56 ID DWORD 2 : E4E34D40 ID DWORD 3 : 7EB41B29 ID DWORD 4 : DE36F848 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum CB SearchForBootstrap_DCT5.. C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 220C -> K5G1257ATM Extended/Fixed ID : 0000 Revision ID : 8921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : DC SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :220C ExtID :0000 RevID :8921 Flash Descriptor Manufacturer Code : 00EC Device ID : 220C Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: A4B03CEB0AC8A915C4ECE9894BC44D6CE68F3AA4 =========================================== PHONE FIRMWARE VERSION: V 05.23 29-10-08 RM-414 (c) Nokia =========================================== Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ help please thx in advance |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
