GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Advance-Box (https://forum.gsmhosting.com/vbb/f609/)
-   -   Few tries later Sucessfully Flashed 5220 01:43 (https://forum.gsmhosting.com/vbb/f609/few-tries-later-sucessfully-flashed-5220-01-43-a-944582/)
Chennairam 03-06-2010 15:05
HEre the error Logs
Try 1
20:07:51 : Processing : rm411__07.23.mcusw
20:07:51 : Total blocks to write : 1289
20:07:51 : >> CMT Rootkey Hash CERT : NOLO
20:07:53 : >> CMT Rootkey Hash CERT : KEYS
20:07:53 : >> CMT Rootkey Hash CERT : PRIMAPP
20:07:53 : >> CMT Rootkey Hash CERT : PASUBTOC
20:07:54 : Flashing FAILED
20:07:54 : Operations Failed....
try2
20:08:18 : Processing : rm411__07.23.mcusw
20:08:18 : Total blocks to write : 1289
20:08:18 : >> CMT Rootkey Hash CERT : NOLO
20:08:18 : >> CMT Rootkey Hash CERT : KEYS
20:08:18 : >> CMT Rootkey Hash CERT : PRIMAPP
20:08:18 : >> CMT Rootkey Hash CERT : PASUBTOC
20:08:18 : >> CMT Rootkey Hash CERT : PAPUBKEYS
20:08:18 : >> CMT Rootkey Hash CERT : UPDAPP
20:08:25 : Flashing FAILED
20:08:25 : Operations Failed....
try3
20:08:46 : Processing : rm411__07.23.mcusw
20:08:46 : Total blocks to write : 1289
20:08:47 : >> CMT Rootkey Hash CERT : NOLO
20:08:47 : >> CMT Rootkey Hash CERT : KEYS
20:08:47 : >> CMT Rootkey Hash CERT : PRIMAPP
20:08:47 : >> CMT Rootkey Hash CERT : PASUBTOC
20:08:47 : >> CMT Rootkey Hash CERT : PAPUBKEYS
20:08:47 : >> CMT Rootkey Hash CERT : UPDAPP
20:09:08 : Flashing FAILED
20:09:08 : Operations Failed....
Try 4 Sucessfully Flashed
http://i123.photobucket.com/albums/o.../5220_1_43.jpg
after Flash fbus Check ... it say security test failed .. but phone working good
http://i123.photobucket.com/albums/o...est_failed.jpg
Ram
X-Shadow 03-06-2010 15:11
@Chennairam
When the flashing stops during errors... Does it hang for a while then give error
message or does it stop and show error message immediately ?
B.R.
X-Shadow
Chennairam 03-06-2010 15:16
Originally Posted by X-Shadow (Post 5531535)
@Chennairam
B.R.
X-Shadow
It will take Few Seconds to Shows Error Message
Br.,
Ram
zeel_zeel 03-07-2010 02:57
The time taken in 4th try is so less b'coz the phone was already erased in 1st try. ATF pattern of flashing is just like usb flashing. Erase required flash area first and then flash it. So if phone is erased in 1st try and one gets error in flashing, then in next try if flashing is successful, naturally the flash time taken is lesser. Actual flash time for 5220 & 7210c is around 5-8 mins and that too depends.
Chennairam 03-07-2010 03:02
yes You are right .. i tested in another 5220 flashing time 8:45sec
Still i am very confused
br
Ram
ulymar 03-07-2010 03:13
hi!
can you attach the full log file so we can check
whats the problem why it stop during flashing..
Some reason why flashing stop caused by driver.
Simlock test problem will be fixed in next and pro version.
br
ulymar
neilthirumuttam 03-07-2010 03:19
du u feel any speed difference while using ext power from ATF to cable ?
I tested on 3110c
N70
3500
etc...
satisfied with its performance in flashing....
Total Flashing Time (Booting + Erase + Flashing) : 00:04:17
X-Shadow 03-07-2010 03:25
Some phones like 7210c takes longer time to flash when VPP is connected
and External VPP is selected. Maybe this is the same case with 5220.
zeel_zeel is correct. Only erasing time takes too long on the 5220. The
flashing time will change only if you select 7.5Mhz or 15Mhz. However
the erasing time for 3Mhz is still the same time in 15Mhz.
We are really tempted to put side by side videos comparing flashing times
of ATF vs another 3rd party box but I think it is really unfair for the other
boxes as they only have 12 mbps USB connection (ATF has 480 mbps USB
connection).
For slow phones like 7210 and 5220, maybe you will see a small difference like
ATF will be 1-3 minutes faster...
But for all other non SLOW phones,,, the other boxes really don't have a fighting
chance... It is brutally unfair to compare.
Frenzy_2020 03-07-2010 03:54
connection).
HERE is a log for a 5220 which other boxes in the market counld not connect to flash even with USB it was throwing up error however i was able to do it via ATF
LOG:
19:15:02 : ******************************************************
19:15:02 :                  TIME START HERE
19:15:02 :
19:15:02 : BootFlashModeDCT5Ex Succeeded First Time
19:15:02 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
19:15:02 : Number of Sub Blocks 7  (0x07)
19:15:02 :  1  SYSTEM_ASIC_ID 01
19:15:02 :      Block Length  : 21  (15)
19:15:02 :      BB ASIC Index : 0  (00)  CMT
19:15:02 :      ID DWORD    0 : 00000001
19:15:03 :      ID DWORD    1 : 00000226
19:15:03 :      ID DWORD    2 : 00010006
19:15:03 :      ID DWORD    3 : 030C1921
19:15:03 :      ID DWORD    4 : 01033000
19:15:03 :  2  ROM_ID 15
19:15:03 :      Block Length  : 5  (05)
19:15:03 :      BB ASIC Index : 0  (00)  CMT
19:15:03 :      ID DWORD    0 : 00000295
19:15:03 :  3  ROM_ID 15
19:15:03 :      ID DWORD    0 : 00000B22
19:15:03 :  4  PUBLIC_ID 12
19:15:03 :      Block Length  : 21  (15)
19:15:03 :      ID DWORD    0 : 1E300217
19:15:03 :      ID DWORD    1 : B11B0354
19:15:03 :      ID DWORD    2 : 6743E139
19:15:03 :      ID DWORD    3 : 483B7653
19:15:03 :      ID DWORD    4 : A8C89017
19:15:03 :  5  ASIC_MODE_ID 13
19:15:03 :      Block Length  : 2  (02)
19:15:03 :      Mode Id      : 00
19:15:03 :  6  ROOT_KEY_HASH 14
19:15:03 :      Block Length  : 17  (11)
19:15:03 :      Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
19:15:03 :  7  ROM_ID 15
19:15:03 :      Block Length  : 9  (09)
19:15:03 :      CRC        0 : 273F6D55
19:15:03 :      CRC        1 : DFAAF68F
19:15:03 : Checksum          F5
19:15:03 : BootCodeLen : 61
19:15:03 : SearchForBootstrap_DCT5..
19:15:03 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
19:15:03 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
19:15:04 : MCU_CONFIGURATION_RESPONSE_BB5:
19:15:04 :  MessageID  : C1
19:15:04 :  SubBlocks  : 03
19:15:04 :  1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
19:15:04 :    Block Length      : 0B
19:15:04 :    BB ASIC Index    : CMT  00
19:15:04 :    Device Type      : NOR  00
19:15:04 :    Device Index      : 00
19:15:04 :    Manufacturer Code : 0089 ->
19:15:04 :    Device ID        : 8982 -> Type not in database
19:15:04 :    Extended/Fixed ID : 0000
19:15:04 :    Revision ID      : 8A31
19:15:04 :  2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
19:15:04 :    Block Length      : 13
19:15:04 :    Device Contents  : 00000000000000000000
19:15:04 :  3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
19:15:04 :    Device Type      : MMC  04
19:15:04 :    Manufacturer Code : FFFF -> Flash
19:15:04 :    Device ID        : 0000 -> BAD FLASH TYPE
19:15:04 :    Revision ID      : 0000
19:15:04 :  Checksum  : 51
19:15:04 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
19:15:04 : FLS1SendAlgoCodeEx..
19:15:04 : SendAlgoCode_DCT5..
19:15:04 : SearchForAlgorithm_DCT5..
19:15:04 : Looking for ALL Devices...
19:15:04 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
19:15:04 : Flash Descriptor
19:15:04 :    Size              : 00400000  (4194304)
19:15:04 :    VPP Info          : 0009
19:15:04 :    Erase10s          : 28
19:15:04 :    Block1s          : 64
19:15:04 :    BErase1s          : 02
19:15:04 :    Reserved0        : 00
19:15:04 :    Reserved1        : 00
19:15:04 :    Reserved2        : 00
19:15:04 : VPP INFO :  VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
19:15:04 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
19:15:04 : SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
19:15:04 : TransmissionTypeRequest_DCT5...
19:15:04 : SuggestedType  : 01 16BIT
19:15:04 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
19:15:04 : ReturnedType : 01 16BIT
19:15:04 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
19:15:04 :
19:15:04 : Uploading ALGO File...
19:15:04 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
19:15:04 : No partition info....
19:15:04 : VPP Enabled by Software
19:15:04 : Using Internal VPP
19:15:04 : StartErase_DCT5...
19:15:04 : BlockLength  :  0x000E  (14)
19:15:04 : ERASE Blocks :  0x0001  (1)
19:15:04 :      0  ERASE_AREA_BB5 0x12
19:15:04 :            Block Length    : 0x0B (11)
19:15:05 :            BB ASIC Index    : 0x00 CMT
19:15:05 :            Device Type      : 0x00 NOR
19:15:05 :            Device Index    : 0x00
19:15:05 :                0            : 01520000-01DBFFFF
19:15:05 : ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4
19:15:05 : Please wait ERASING.........
19:15:36 : Status_BB5 STATUS_REQUEST_BB5..
19:15:36 :    1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
19:15:36 :            Block Length      : 01
19:15:36 :            BB ASIC Index    :  00
19:15:36 : Successfully erased..
19:15:36 : Time Taken to Erase : 00:00:31
19:15:36 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
19:15:36 : ReturnedType : 04 DDRand2TX
19:15:36 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
19:15:36 :
19:15:37 : Is Flashing CLOCK AUTO : -1
19:15:37 : Processing  : rm411__07.23.ppm_a
19:15:37 : Total blocks to write : 435
19:15:54 : ContinueFlash_DCT5 Complete
19:15:54 : Status_BB5 STATUS_REQUEST_BB5..
19:15:54 :    1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
19:15:54 :            Block Length      : 01
19:15:54 :            BB ASIC Index    :  00
19:15:54 : FlashInfo.RestartMode : 2
19:15:54 : Continue Flash Complete :  : No Error - 0 (0x00)
19:15:54 : Time Taken to Flash  : 00:00:17
19:15:54 : Making delay between files for 1000ms
19:15:55 : AdvanceBox Turbo Flasher Found
19:15:55 : Driver Version : 00020422
19:15:55 : Library Version : 00030119
19:15:55 : Initialize Device....
19:15:56 : Init TRY : 1
19:15:56 : Changing Clock to 15mhz..
19:15:56 : Box Name : AdvanceBox Turbo
19:15:56 : Box Firmware : LogiCore 1.16.10
19:15:56 : Software Version : v2010.0.1.21
19:15:56 : AdvanceBox SN : E20B7CC5BA1A6FE0F0D092A5
19:15:56 : BOX Status : ACTIVATED
19:15:56 : DDR DELAY  :  01
19:15:56 : INIT : OK
19:15:56 :
19:15:56 : Processing Image File : C:\Documents and Settings\clifford\Desktop\New Folder\rm411__07.23.image_a_a_green
19:15:56 : CMT Type : BB5
19:15:56 : CMT Algorithm : BB5 ALGORITHM
19:15:56 : CMT Supported Hardwares :
19:15:56 :                          > 010C192101013000
19:15:56 :                          > 0103192101003000
19:15:56 :                          > 030C192101033000
19:15:56 : Secondary Sending Speed    :  3250000Hz
19:15:56 : Algorithm Sending Speed    :  6500000Hz
19:15:57 : Program Sending Speed      :  6500000Hz
19:15:57 : Message Reading Speed      :  98000Hz
19:15:57 : Number of Blocks :  688
19:15:57 : Entry Point:  0x00C2
19:15:57 : Page Format : -1
19:15:57 : MAX PAGE : 0x00004000
19:15:57 : AdvanceFBox SendBootCodeEx
19:15:57 : InitialiseBootstrap_DCT5 DIR
19:15:57 : BootFlashMode_DCT5
19:15:57 : AdvanceBox Turbo Flasher Found
19:15:57 : Driver Version : 00020422
19:15:57 : Library Version : 00030119
19:15:57 : Initialize Device....
19:15:57 : Init TRY : 1
19:15:57 : Changing Clock to 15mhz..
19:15:58 : Box Name : AdvanceBox Turbo
19:15:58 : Box Firmware : LogiCore 1.16.10
19:15:58 : Software Version : v2010.0.1.21
19:15:58 : AdvanceBox SN : E20B7CC5BA1A6FE0F0D092A5
19:15:58 : BOX Status : ACTIVATED
19:15:58 : DDR DELAY  :  01
19:15:58 : INIT : OK
19:15:58 :
19:15:58 : VBATT OFF ...
19:16:01 : VBATT ON
19:16:01 : Setting VBATT Done!...
19:16:02 : AdvanceFBox SendBootCodeEx
19:16:02 : InitialiseBootstrap_DCT5 DIR
19:16:02 : BootFlashMode_DCT5
19:16:02 :
19:16:02 : ******************************************************
19:16:02 :                  TIME START HERE
19:16:02 :
19:16:02 : BootFlashModeDCT5Ex Succeeded First Time
19:16:02 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
19:16:02 : Number of Sub Blocks 7  (0x07)
19:16:02 :  1  SYSTEM_ASIC_ID 01
19:16:02 :      Block Length  : 21  (15)
19:16:02 :      BB ASIC Index : 0  (00)  CMT
19:16:02 :      ID DWORD    0 : 00000001
19:16:02 :      ID DWORD    1 : 00000226
19:16:02 :      ID DWORD    2 : 00010006
19:16:02 :      ID DWORD    3 : 030C1921
19:16:02 :      ID DWORD    4 : 01033000
19:16:02 :  2  ROM_ID 15
19:16:02 :      Block Length  : 5  (05)
19:16:02 :      ID DWORD    0 : 00000295
19:16:02 :  3  ROM_ID 15
19:16:02 :      ID DWORD    0 : 00000B22
19:16:02 :  4  PUBLIC_ID 12
19:16:02 :      ID DWORD    0 : 1E300217
19:16:02 :      ID DWORD    1 : B11B0354
19:16:02 :      ID DWORD    2 : 6743E139
19:16:02 :      ID DWORD    3 : 483B7653
19:16:02 :      ID DWORD    4 : A8C89017
19:16:02 :  5  ASIC_MODE_ID 13
19:16:02 :      Block Length  : 2  (02)
19:16:02 :      Mode Id      : 00
19:16:02 :  6  ROOT_KEY_HASH 14
19:16:02 :      Block Length  : 17  (11)
19:16:02 :      Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
19:16:02 :  7  ROM_ID 15
19:16:02 :      Block Length  : 9  (09)
19:16:02 :      CRC        0 : 273F6D55
19:16:02 :      CRC        1 : DFAAF68F
19:16:02 : Checksum          F5
19:16:02 : BootCodeLen : 61
19:16:03 : SearchForBootstrap_DCT5..
19:16:03 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
19:16:03 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
19:16:03 : MCU_CONFIGURATION_RESPONSE_BB5:
19:16:03 :  MessageID  : C1
19:16:03 :  SubBlocks  : 03
19:16:03 :  1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
19:16:03 :    Block Length      : 0B
19:16:03 :    BB ASIC Index    : CMT  00
19:16:03 :    Device Type      : NOR  00
19:16:03 :    Device Index      : 00
19:16:03 :    Manufacturer Code : 0089 ->
19:16:03 :    Device ID        : 8982 -> Type not in database
19:16:03 :    Extended/Fixed ID : 0000
19:16:03 :    Revision ID      : 8A31
19:16:03 :  2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
19:16:03 :    Block Length      : 13
19:16:03 :    Device Contents  : 00000000000000000000
19:16:03 :  3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
19:16:04 :    Block Length      : 0B
19:16:04 :    BB ASIC Index    : CMT  00
19:16:04 :    Device Type      : MMC  04
19:16:04 :    Device Index      : 00
19:16:04 :    Manufacturer Code : FFFF -> Flash
19:16:04 :    Device ID        : 0000 -> BAD FLASH TYPE
19:16:04 :    Extended/Fixed ID : 0000
19:16:04 :    Revision ID      : 0000
19:16:04 :  Checksum  : 51
19:16:04 : SearchForBootstrap_DCT5  : No Error - 0 (0x00)
19:16:04 : FLS1SendAlgoCodeEx..
19:16:04 : SendAlgoCode_DCT5..
19:16:04 : SearchForAlgorithm_DCT5..
19:16:04 : Looking for ALL Devices...
19:16:04 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
19:16:04 : Flash Descriptor
19:16:04 :    Manufacturer Code : 0089
19:16:04 :    Device ID        : 8982
19:16:04 :    Size              : 00400000  (4194304)
19:16:04 :    VPP Info          : 0009
19:16:04 :    Erase10s          : 28
19:16:04 :    Block1s          : 64
19:16:04 :    BErase1s          : 02
19:16:04 :    Reserved0        : 00
19:16:04 :    Reserved1        : 00
19:16:04 :    Reserved2        : 00
19:16:04 : VPP INFO :  VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
19:16:04 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
19:16:04 : SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
19:16:04 : TransmissionTypeRequest_DCT5...
19:16:04 : SuggestedType  : 01 16BIT
19:16:04 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
19:16:04 : ReturnedType : 01 16BIT
19:16:04 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
19:16:04 :
19:16:04 : Uploading ALGO File...
19:16:04 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
19:16:05 : No partition info....
19:16:05 : VPP Enabled by Software
19:16:05 : Using Internal VPP
19:16:05 : StartErase_DCT5...
19:16:05 : BlockLength  :  0x0016  (22)
19:16:05 : ERASE Blocks :  0x0001  (1)
19:16:05 :      0  ERASE_AREA_BB5 0x12
19:16:05 :            Block Length    : 0x13 (19)
19:16:05 :            BB ASIC Index    : 0x00 CMT
19:16:05 :            Device Type      : 0x00 NOR
19:16:05 :            Device Index    : 0x00
19:16:05 :                0            : 01DC0000-0215FFFF
19:16:05 :                1            : 02160000-03FBFFFF
19:16:05 : ERASE_REQUEST_BB5 : 5001121300000001DC00000215FFFF0216000003FBFFFFD3
19:16:05 : Please wait ERASING.........
19:19:50 : Status_BB5 STATUS_REQUEST_BB5..
19:19:50 :    1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
19:19:50 :            Block Length      : 01
19:19:50 :            BB ASIC Index    :  00
19:19:50 : Successfully erased..
19:19:50 : Time Taken to Erase : 00:03:45
19:19:50 : TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
19:19:51 : ReturnedType : 04 DDRand2TX
19:19:51 : TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
19:19:51 :
19:19:51 : Is Flashing CLOCK AUTO : -1
19:19:51 : Processing  : rm411__07.23.image_a_a_green
19:19:51 : Total blocks to write : 688
19:20:17 : ContinueFlash_DCT5 Complete
19:20:17 : Status_BB5 STATUS_REQUEST_BB5..
19:20:17 :    1  Sub Block ID      :  14 STATUS_NOR_OK_BB5
19:20:17 :            Block Length      : 01
19:20:17 :            BB ASIC Index    :  00
19:20:17 : FlashInfo.RestartMode : 2
19:20:17 : Continue Flash Complete :  : No Error - 0 (0x00)
19:20:17 : Time Taken to Flash  : 00:00:26
19:20:17 : Making delay between files for 1000ms
19:20:18 :
19:20:18 : Total Flashing Time (Booting + Erase + Flashing) : 00:06:16
19:20:18 :
thanks ATF
s1emens 04-16-2010 18:12
strange i also need about 8min more to flash 5220 but when flashing 6303 only need 1min more, 3110c need about 4min more. Or maybe for 5220 alike need VPP from extension port?
br,
s1emens
Page generated in 0.35181 seconds with 5 queries
