Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 51
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,352 | <<< First in the World ATF present Nokia 105 RM-908 flash file >>> First in the World ATF present Nokia 105 RM-908 flash file ![]() Download link - https://www.mediafire.com/?sq65nht8s258d7k Software Version : 2.70 Product Type : RM-908 Arabic + Urdu + English Br - srinibas Last edited by srinibas; 12-05-2013 at 15:20. |
The Following 72 Users Say Thank You to srinibas For This Useful Post: |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | @srinibas What Languages and Firmware Version are inside the Phone which you read the Flash File from? Please Provide Info for end users. I have Chinese, Filipino is anyone is interested. Version 02.70 only |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
![]() | #3 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
With the Help of some very generous person from Hungary, read flash via FBUS is now supported. But some BIGGER sized PPM and CNT will still not be supported via FBUS as of this moment. | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
![]() | #4 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,352 | Quote:
Use 7 zip to unzip it - http://www.7-zip.org/download.html Br - srinibas | |
The Following 4 Users Say Thank You to srinibas For This Useful Post: |
![]() | #9 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,352 | |
The Following User Says Thank You to srinibas For This Useful Post: |
![]() | #14 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 476 ![]() | Quote:
HandSet Dead After Flashing With Given Flash File Need Help Plz It Was Fully Working HandSet Only Blinking When Insert Sim Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-908\rm908_03.400 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-908\rm908_03.40mg PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-908\rm908_nai03.40mg CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:56 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 03.40 08-08-13 RM-908 (c) Nokia IMEI: 358146058145862 Product Serial Number: 20250F4BH Product Code : 059R449 Module Code : 0205453 Basic Production Code: 059Q858 PPM SW Version : V 03.40 08-08-13 RM-908 (c) Nokia MG ADSP Version : p no NAI version MCU SW Version : V 03.40 08-08-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BEIHAIv82 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK | |
