12-26-2013, 10:03 | #51 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00EF Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-908\RM-908\rm908_03.400 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 0551 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2232896 bytes Data Checksum: 89F6 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-908\RM-908\rm908_03.40ij PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x0039A33E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1614656 bytes Data Checksum: 6B15 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-908\RM-908\rm908_nai03.40ij CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F161BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 418240 bytes Data Checksum: 7E6F Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:01:54 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 03.40 08-08-13 RM-908 (c) Nokia IMEI: 358347052179978 Product Serial Number: 22048EDBH Product Code : 059R449 Module Code : 0205453 Basic Production Code: 059Q858 PPM SW Version : V 03.40 08-08-13 RM-908 (c) Nokia IJ ADSP Version : p V 03.40\n08-08-13\nRM-908\n(c) NMP\nij MCU SW Version : V 03.40 08-08-13 RM-908 (c) Nokia HW Version : 1001 UEM Version : 1328 UPP Version : 8850 LCD Version : CMI:BEIHAIv01 ILI9163C ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK |
The Following User Says Thank You to Shani3 For This Useful Post: |
