03-04-2014, 14:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | Atf 11.10 not working after update ::::::::::::::::::::::::::::::::::>>>>>>>>>>>>>>>> >>>>>> Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-04-2014, 15:08 | #3 (permalink) |
Freak Poster Join Date: Apr 2011 Location: punjab
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | I have same problem shine star electronics |
03-16-2014, 09:30 | #5 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 550428 Status: Offline Thanks Meter: 25 | i also in the same problem, but after i press stop then can use like normal.. is there got other solution to solve it? my computer don have anti virus and i already add ATF to Exception List still not working normally.. thankyou |
03-27-2014, 15:36 | #6 (permalink) |
Crazy Poster Join Date: Aug 2011
Member: 1631454 Status: Offline Thanks Meter: 9 | Until Solved I Dont Buy It! ATF Nitro Until Solved I Dont Buy It! ATF Nitro!! I really need it but If the Team dont make a solution soon then Ill have to make another selection. BRs, LDAR |
The Following User Says Thank You to mctsofpr For This Useful Post: |
03-28-2014, 06:11 | #7 (permalink) |
Freak Poster Join Date: Jul 2002 Location: GSM-FORUM
Member: 13726 Status: Offline Thanks Meter: 1 | Atf 11.10 is not perfect.....so...guys you have to uninstall any version first....then install v11.00.....then you update with version 11.10.... This will solve most of the problems....try it |
03-28-2014, 12:10 | #8 (permalink) |
Junior Member Join Date: Apr 2008
Member: 742407 Status: Offline Thanks Meter: 12 | Sir, i uninstall ATF and driver and install v11.10 by auto update. ATF exe run normally if i disconnect usb from box and connect box again and run ATF exe its not open. task manager show atf not responding. if i click End process its not ending from desktop. after restart pc same problem. i format pc and direct install v11.10 and update important files and add ATF exe to AV exception list but the problem same. i use MSE antivirus and xp sp-2. how can solve this problem? |
03-28-2014, 12:57 | #9 (permalink) | |
Member: 13726 Status: Offline Thanks Meter: 1 | Quote:
That happened to me also....that's why i said.......u uninstall any versions from pc then INSTALL V11.....THEN INSTALL V11.10 VERSION OVER IT.......follow the instructions.. | |
03-28-2014, 13:06 | #10 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | i am also facing this problem. i downloaded full installer and installed it but when i open atf there is nothing. look it---- http://imageshack.com/a/img34/1863/dleg.png |
