Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-10-2014, 11:40   #16 (permalink)
Member: 278546
Thanks Meter: 145
if possible made me sdc. i am using 32gb kingston . i did every thing right . but not done.
Old 12-10-2014, 11:46   #17 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Post screeshoot of what have done....of "every thingh".
This Kingston are sure not is Fake one?, Sd card is very important, if is NOT original phone not detect this, anyway post screenshoot
allumts
Old 12-12-2014, 15:02   #18 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
problem in creating sdc file
when i creat samsung i9500 android 4.4.2 its show only 600kb
here is i attached pic
were i m wrong please chek.
1st image with genric it file
and 2nd image with og pit file
Old 12-12-2014, 15:30   #19 (permalink)
allumts's Avatar
Member: 1564612
Why you select PDA and no BL?, you cannot see alone where's the ERROR?
BL +PIT for create Sdc file by yourself, NOT AP/PDA+PIT. (ONLY SINGLE FILE BL)
Read good the procedure
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 12-12-2014, 16:28   #20 (permalink)
allumts's Avatar
Member: 1564612
Loock good this photo, created my Sdc file w/o issues at first time:
allumts
Old 12-13-2014, 06:32   #21 (permalink)
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
same issue when i select only BL+PIT and written file version.
can you chek my pc via taem viever where i m wrong
Old 12-13-2014, 08:51   #22 (permalink)
allumts's Avatar
Member: 1564612
Is all ok in you pc, issue can be in card you use but i think most important Wich file you use,
please Post here File Used for create by yourself Sdc file: BL and PIT
and remember that you are using only BL+PIT, size cannot be the same how if use 4 file fw+ PIT, but is working the same.
allumts
Old 12-14-2014, 11:08   #23 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@moinuddin111
SDC is OK as long as you use BL + PIT. Also, this is Exynos CPU and file size for these CPU SDC is: 230+ Kbs to 600+ Kbs
For Qualcomm CPUs: 3MB+ to 32+MB MAX
Old 12-18-2014, 02:27   #24 (permalink)
Özkaya's Avatar
Member: 2041919
Sonork: 1111006
Thanks Meter: 88
hey
Bro I needed file SM-G900P SDC file thanks advance team.
Old 12-18-2014, 02:29   #25 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Originally Posted by Özkaya View Post
hey
Check Here:
ATF Offcial Support Area > Samsung SDC Files > SM-G900P
Old 12-24-2014, 13:04   #26 (permalink)
Member: 1309495
Sonork: bishop
just ask i dont know much about atf, is there any brand aside from nokia supported by atf?
Old 12-24-2014, 13:17   #27 (permalink)
Member: 1309495
Sonork: bishop
how much is advance box in philippine currency please i just need to know so that i can buy my own
Old 12-24-2014, 23:15   #28 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
@Advance-Box
@..::Angel::..
@allumts
Respected Sir
I Am Confused On
" Generic PIT "
Old 12-26-2014, 12:36   #29 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by shoaibrao View Post
@Advance-Box
@..::Angel::..
@allumts
Respected Sir
I Am Confused On
" Generic PIT "
Read in previous page this my post, for sure you will be more clear all:
http://forum.gsmhosting.com/vbb/10717329-post9.html
allumts
Old 12-30-2014, 12:52   #30 (permalink)
Member: 656769
Thanks Meter: 3
sir i have a question can i make a sdc file from a sam i5800 bootloader file... it is deadboot... it has no recovery. it hangs on i5800 logo... if possible what are the settings to be used.?
The Following User Says Thank You to jolly88888 For This Useful Post:
Page generated in 0.25699 seconds with 9 queries
