Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-12-2012, 10:15   #1 (permalink)
Member: 834998
Thanks Meter: 17
5130 always restarting need help
anybody can help me
5130 always restarting but complete flashing in atf
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 1E100108
ID DWORD 1 : 182B8E56
ID DWORD 2 : 16699B4F
ID DWORD 3 : 653DAD0C
ID DWORD 4 : C9CCC843
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
ADL_SERVER: PROCESSING rm495__07.97.mcusw
ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
ADL_SERVER: CMT DATA BLOCKS FOUND
ADL_SERVER: CONSOLIDATING CMT BLOCKS
ADL_SERVER: PASUBTOC BLOCK FOUND
BB5 ADL Loader Start Up... (Please Wait...)
Found Nokia BB5 ADL Loader USB Generic...
Processing : rm495__07.97.mcusw
Erase Block Found
>> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00140000 - 0x0137FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x01380000 - 0x0151FFFF, Type: NOR , Subsystem: CMT
Erase Complete : No Error - 0 (0x00)
Data Block Found : 1178 Blocks
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
Continue Flash Complete : No Error - 0 (0x00)
Processing : rm495__07.97.ppm_t
Erase Block Found
>> Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 475 Blocks
Processing : rm495__07.97.image_t_ph_red
Erase Block Found
>> Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 656 Blocks
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:07:04
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 07.97 13-09-10 RM-495 (c) Nokia
IMEI: 351538041529235
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : PASSED
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
Old 07-12-2012, 10:16   #2 (permalink)
W4r10rD's Avatar
Member: 183043
Thanks Meter: 68
Have you replaced the lcd?
Old 07-12-2012, 10:19   #3 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
@cocobaycity
bro its hardware problem.. remove the camera and check ur set...
bro
Old 07-13-2012, 04:16   #4 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
or change air speaker 100% ok
The Following 2 Users Say Thank You to niaz muhammad For This Useful Post:
Old 07-13-2012, 04:43   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ cocobaycity
Do SD / CMLA Check >>>>> If found OK then check hardware
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 07-13-2012, 05:20   #6 (permalink)
ROYAL-GSM's Avatar
Member: 281547
Sonork: 100.1609533
Thanks Meter: 162
Originally Posted by cocobaycity View Post
anybody can help me
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Erase Block Found
Erase Block Found
Erase Block Found
Flashing Done...
SIMLOCK TABLE :
SL3 Phone detected
OK
OK
OK
OK
OK
OK
hello dear carefully resold dual combo memory ic solution is 100%
The Following User Says Thank You to ROYAL-GSM For This Useful Post:
Old 07-13-2012, 08:01   #7 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
yes mostly 5130,2700,2730 phone restarted problem
combo ic
check this link
http://forum.gsmhosting.com/vbb/f299...n-off-1111927/
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 07-13-2012, 08:04   #8 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
http://forum.gsmhosting.com/vbb/f299...olved-1057604/
The Following 2 Users Say Thank You to DHEERAJ_SHARMA For This Useful Post:
Old 07-13-2012, 08:06   #9 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
if not solved via software 100% combo ic tested me here
br
The Following 2 Users Say Thank You to ernie78™ For This Useful Post:
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.20970 seconds with 9 queries
