How return DLOAD mode? Hello! I have lumia 710 which only vibrate. Flashing fine, but again only vibrate and dont turn on. Phone was repaired by writing "OSBL Qualcomm" and partition from "RM-803_RM-809_BOOTS_RAW". After restore "OSBL DLOAD" (TAB "TP services") phone dont turn on and dont flash. I try again "OSBL Qualcomm" and partition from "RM-803_RM-809_BOOTS_RAW". After this press "Restore Dload": 20:47:26 : Loading Partition File: H:\AdvanceBox Turbo Flasher\ATF\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\RM-803_RM-809_BOOTS_RAW\RM-803_RM-809_BOOTS_RAW\dbl_RM-803_RM-809.bin 20:47:26 : Writing Partition 0x4D 20:47:27 : Partition 0x4D Write OK 20:47:27 : 20:47:27 : Total Elapsed Time 00:00:00 20:47:35 : 20:47:35 : Loading Partition File: H:\AdvanceBox Turbo Flasher\ATF\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\RM-803_RM-809_BOOTS_RAW\RM-803_RM-809_BOOTS_RAW\osbl_nokia_RM-803_RM-809.bin 20:47:35 : Writing Partition 0x46 20:47:36 : Partition 0x46 Write OK 20:47:36 : 20:47:36 : Total Elapsed Time 00:00:00 20:47:43 : 20:47:43 : Loading Partition File: H:\AdvanceBox Turbo Flasher\ATF\AdvanceBox Turbo Flasher\Nokia\Lumia\partitions\RM-803_RM-809_BOOTS_RAW\RM-803_RM-809_BOOTS_RAW\amss_adsp_RM-803_RM-809.bin 20:47:43 : Writing Partition 0x0C 20:48:12 : Partition 0x0C Write OK 20:48:12 : 20:48:12 : Total Elapsed Time 00:00:28 20:48:25 : 20:48:25 : Restoring DLOAD OSBL... 20:48:25 : Writing Partition 0x46 20:48:26 : 20:48:26 : Nokia OSBL (DLOAD) Restore OK... 20:48:26 : 20:48:26 : Total Elapsed Time 00:00:01, but phone again cant flashing: 20:53:10 : Sending OSBL Certificate 20:53:10 : HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 20:53:10 : Certificate Size: 452 Bytes 20:53:10 : Status : WRITE OSBL CERTIFICATE FAILED 20:57:29 : 20:57:29 : ERROR: Qualcomm MMC Storage is NOT FOUND How return DLOAD for flashing ? :confused: |
Select Model from Windows Phone tab Go to "eMMC Direct" tab Press VOL UP and connect USB cable to powered off phone Click on "Scan Partitions" Click on "Restore DLOAD" |
recan21 , read carefully logs: 20:48:25 : Restoring DLOAD OSBL... 20:48:25 : Writing Partition 0x46 20:48:26 : 20:48:26 : Nokia OSBL (DLOAD) Restore OK... 20:48:26 : 20:48:26 : Total Elapsed Time 00:00:01, |
Dear sir:D:D:D Did you try to write WP_OS partition with *boot.esco file from firmware for your phone? |
make tp to be sure DLOAD WELL RESTORE... |
Hi, Windows sometimes prevents writing on USB. But TP will write it 100% for sure. Code: 20:48:25 : Restoring DLOAD OSBL... BR |
How to Restore Dload Bootloader from Qualcomm Bootloader How to Restore Dload Bootloader from Qualcomm Bootloader youtube link this tested by me 2 times 1. Lumia 710 2. Lumia 800 RM-801 |
Select Model from Windows Phone tab Go to "eMMC Direct" tab Press VOL UP and connect USB cable to powered off phone Click on "Scan Partitions" Click on "Restore DLOAD" tested and working 2 piece lumia 800 |
so....nothing...afer restore dload Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
