Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-13-2020, 03:50   #1 (permalink)
zorgy_1979's Avatar
Member: 1331464
Thanks Meter: 206
How to save ATF activation
You must have computer, where you have working atf. At first run HardDiskSerialNumberChanger and see you serial on commputer with working ATF. Save this number by NotePad.
After it install atf or copy atf folder from working computer. Copy *.rsa file and run HardDiskSerialNumberChanger. Write serial from computer with working atf and restart. Atf will work offline.
Take solution here https://gsmforum.ru/threads/%D0%90%D.../#post-1371568
The Following 3 Users Say Thank You to zorgy_1979 For This Useful Post:
Old 12-26-2020, 11:01   #2 (permalink)
Member: 392149
Thanks Meter: 199
Anyone tested this solution?
Old 12-28-2020, 14:25   #3 (permalink)
Registered User
Member: 2608490
Thanks Meter: 921
Thank You Man. Its 100% Tested & working Solution.
Old 01-03-2021, 13:03   #4 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 824
unable write to the disk in drive error?
Old 01-07-2021, 09:04   #5 (permalink)
Member: 1404722
Thanks Meter: 46
thanks.tested 100% works.
Old 01-15-2021, 18:10   #6 (permalink)
Member: 1627441
Thanks Meter: 2
Do you tell us the way, even in pictures?
Old 02-13-2021, 17:06   #7 (permalink)
Member: 565739
Thanks Meter: 93
copy all the contents of the folder to a usb memory, the usb memories let you change the SN easier and you can open the program there, tested by me
Old 02-14-2021, 14:19   #8 (permalink)
Member: 226845
Thanks Meter: 78
pls, share a file (*.rsa) from a working atf computer.
Old 03-01-2021, 15:22   #9 (permalink)
Member: 1242985
Would this solution work if I use another Box and windows RSA file and hdd serial number?
Old 03-01-2021, 15:23   #10 (permalink)
Member: 1242985
Would this solution work if I use another Box and windows RSA file and HDD serial number?
Page generated in 0.18107 seconds with 9 queries
