Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-13-2015, 08:40   #1 (permalink)
Member: 837836
Thanks Meter: 7
How To Unbrick I8200 - (SUCCESS STORY + BOOT FILES + VIDEOS INSIDE)
Hi to all
how to repiare boot samsung i8200 ?
this phone flashed by correct flash file
help me
The Following User Says Thank You to saeidz For This Useful Post:
Old 02-13-2015, 21:50   #2 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
Originally Posted by saeidz View Post
Hi to all
help me
our team are working on this problem...
But just way up now is desoldering emmc and program it ...
The Following User Says Thank You to CoMoBat For This Useful Post:
Old 02-15-2015, 03:38   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
This phone eMMC NO NEED to desilder from PCB.
Only need correct PINOUT and correct Vcc 3.3V and VccQ 1.8V.
If emmc cannot be detected, then it means you are using wrong pinout or maybe using a wrong power supply.
Use search button, I already posted pinout and I have this phone with me as well. Even totally empty emmc USER, BOOT1 and BOOT2 can be detected by any ATF Box with eMMC Tool.
The correct adapter to use is still Smart GSM 4-in-1 V2. If you buy clone adapter or other brand then maybe you will get problems with this phone.
The Following 3 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-15-2015, 09:59   #4 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
But before it, many of supporter told to users it is not possible !
But we test it and post result here...
Old 02-15-2015, 10:44   #5 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
Mr X-Shadow;
Is this pinuot correct ?
http://oi57.tinypic.com/2vj6jhx.jpg
Old 02-15-2015, 13:29   #6 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
There are 2 point with write CMD, one of this must be CLK point, (i think is no in resistor), need to ceck with Atf pin finder...
allumts
The Following 3 Users Say Thank You to allumts For This Useful Post:
Old 02-15-2015, 15:00   #7 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
allumts
My user forum has phone in his hand
I modify pinout and told him for checking....
but is possible no pinout for CLK on PCB?
becuse some users and admin told in this forum not possible for direct emmc....
also Mr Babak Nuri in one post told user that he can repair boot of this model just by USB cable and that solution is private....
whats iss your edia about this solution?
Old 02-15-2015, 15:33   #8 (permalink)
allumts's Avatar
Member: 1564612
Here is Atf section and no section of RIFF box.
You have full answere from OUR Admin "Advance Box" above, so who listen you @Babak Nuri or our Admin that have wrote clear that is possible try with eMMc direct?
What say other peoples not import, just read other time here:
From @Advance Box, OUR Admin of this section, so if want listen good if no you are free of do wath you want.
And not change the thinghs, here nothingh to talk about USB cable.
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 02-15-2015, 19:14   #9 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 150
Bro I founded your post in below link
http://forum.gsmhosting.com/vbb/10832160-post6.html
I copy it for my forum user and wait for his response ...
Thanks.
Old 02-21-2015, 22:44   #10 (permalink)
Member: 837836
Thanks Meter: 7
Thanks.
i tested this picture but my problem not sloved
not detect in atf
Old 02-22-2015, 01:26   #11 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
First,Of Course This is not RIFF Section and we never speak about that.
Then,I never say I8200 Can't Detect and Can't Work Via ATF...For Sure Can Work Because I did repair many I8200n (over 50pcs) by ATF
I say in Easy-JTAG Section about this tool can't detect I8200 CPU
http://forum.gsmhosting.com/vbb/10810232-post26.html
Also I say I8200 CPU can't Halt over JTAG With RIFF Box,(Ofcourse in RIFF Section)
http://forum.gsmhosting.com/vbb/10862649-post2.html
And Finally.Yes I Have Signed Loader For Repair EMEI Loader Based Phone Just With USB Cable
So.Please Next Time Read Carefully what people say,Then Answer Them
Thanks
Best Regard ATF Team
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 02-22-2015, 12:48   #12 (permalink)
allumts's Avatar
Member: 1564612
Hi, i not have wrote nothingh of wrong about you.
You are good developer in Riff box and these thinghs and if i've need for my RIFF i ask you or Legija or post in Riff section, is right.
Here i've only replied to the user becouse there's Full answere above by @X-Shadow and him was continue posting one photo of Pinout with 2 CMD point, w/o CLK.
Now, here are reading Atf User and seeing this photo where fault CLK and have 2 CMD point, will have posted ....Why, Where are CLK...Wires for ATF itc...
About this:
Good, we now have 2 way for solve this!!!!
P.d. if you loock good, him has Quoted "X-Shadow" for his doubts...has quoted to me only about the 2 CMD point and no CLK.
About answer this user, in very many post his is replyng on all, often with wrong solution, so for me any problem and all clear
allumts
Old 02-27-2015, 13:58   #13 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
You are smart man...
Totally you right..we never can lost "Clock"...Also ATF used 2 pin of RJ-45 for Best result of Clocking(Can use 1pin or 2 pin).....This is Stupid question about 2 CMD
The Following 2 Users Say Thank You to BABAK NURI For This Useful Post:
Old 02-27-2015, 14:08   #14 (permalink)
Member: 651945
Originally Posted by BABAK NURI View Post
Hi
Nice to have EMEI Loader
The complication about connecting this phone via eMMC is always POWER problem for most users. The VccQ sink a lot of mA because other chips on the PCB is "stealing" power from it. So if your VccQ source is a tiny 20 mA voltage regulator feeding off the USB port, then it will cause problems. However, if you use correct emmc power adapter or use external power supply, then problems will go away.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-27-2015, 15:23   #15 (permalink)
Member: 651945
@ALL
See short video showing GT-i8200 connecting with ATF Box via Original SmartGSM 4-in-1 V2 adapter.
http://174.120.45.27/tmp/GT-i8200.MOV
Page generated in 0.28965 seconds with 9 queries
