03-08-2013, 11:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | Lumia 800 unlock error VIA tp??? 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 9A924344 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! |
03-08-2013, 13:16 | #5 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | THanks for FAST turbo help .... 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 9A924344 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:21:49 |
