12-02-2013, 13:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Want to unlock lumia 610 i am going to buy activation of jtag, i need test points for 610, test points are available in installer ? |
12-02-2013, 15:12 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Check Pinouts Here: http://forum.gsmhosting.com/vbb/f609...22/index3.html Just Solder to those Pinouts and click 1 button in ATF JTAG Software. The Codes will be read after few seconds. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-03-2013, 12:37 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @darmobiles You need to install latest ATF JTAG Version... as I can see from your screenshot, it is not the latest version. Download Here: ATF_JTAG_v1.04_3273_Full_Installer - Download - 4shared Anyway, yes, you need to select that file via ATF JTAG Software button "SELECT PHONE". |
12-03-2013, 13:35 | #6 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | i install new version and phne connect ok but facing this issue please help me where i am wrong? i am doing every step on time but still this error |
12-03-2013, 13:50 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @darmobiles Your JTAG Connection is not OK. Make sure you are using JTAG connection and not old eMMC TP Connection. Make your JTAG connection perfect, and you will be able to unlock phone. That is the only way to do it. |
12-03-2013, 14:04 | #8 (permalink) |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | i am using old nokia cable,and connection is ok because in first step phone connects perfectly. second step don,t know why do connect to software |
12-03-2013, 14:35 | #9 (permalink) | |
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Quote:
i am very new user in jtag field Thanks | |
12-03-2013, 15:20 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @dharmobiles When you loaded 610 unlock in select phone, it showed you where to connect the JTAG via an RJ-45 connector. Follow this and do not use more than 4 inches if wire. First step detects, because step checks USB connection of phone to PC. Then it asks you to disconnect USB cable after about 15 seconds... Then next step ia to connect USB cable again, this time to check JTAG connection. If second step fail, then JTAg connection is wrong. |
12-03-2013, 16:52 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @bighiner Means USB event is not recognized... Possible causes: 1. No Drivers Installed for Lumia DLOAD 2. Wrong Test Points Used (eMMC instead of JTAG) 3. Phone has Qualcomm OSBL Inside (Put back Nokia DLOAD) |
12-03-2013, 17:01 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @bighiner Easier solution is just to use V2 Unlock File. Download and use this: http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar Close Zune and stop Zune process in task bar.. This will make it easier for you. YOU NEED TO FOLLOW INSTRUCTIONS... Software TELLS you to DISCONNECT USB CABLE before starting the Read Codes procedure. If USB cable is already connected before starting, then it will never work.. Just follow instructions, it is really really really really easy to unlock these phones. The hard part is just soldering the wires,, which you already DONE! So now, just follow instructions about disconnect and connecting USB cable ... |
