I8200n dead boot I8200n dead boot support? If yes how |
Sir can do anything with todays update, i think this is marvel cpu based phone |
Hi. Make Clear Picture of phone PCB. Then we can see if pinout is same as my GT-I8200L |
@anwar.welltech Hi, It is the same. Tested Pinouts: Take note of SMALL TP Pads which I show that needs to be connected to Ground. http://174.120.45.27/tmp/GT-i8200N_eMMC_PINOUT.jpg Now Connect with ATF RJ-45 http://174.120.45.27/tmp/ATF_EMMC_UNIVERSAL.jpg For Boot Files, I still need to make it for you. Just Try to connect eMMC first and dump BOOT1 + BOOT2 (32MB each) and USER Partition 512 MB for backup purposes. Only use correct 1.80V and 3.30V external power supply. Using other voltages will not work properly. If eMMC is hard to be detected by ATF Software, just disconnect RJ-45 Cable and try again. Once connection is established, you will be able to dump properly. B.R. |
after i try with gpg 4 in 1 adapter, not detect emmc also heating emmc, set was working fine before i flash |
Hi i was tested with atf and easyjtag both not working Easy: Can't init EMMC, Reason: CMD Timeout Error ATF: Establishing connection...... The brown tp between the proc and the emmc connected to the ground and all soldering fine and triple checked. Made by me under microscope :) |
Hello. I have a dead i8200n (killed by me with wrong flash and pit file, now recognised via USB as EMEI), and was wondering if boot files (.mmc) are available for this model? Br d3m0n |
hello bro you have dump BOOT1 + BOOT2 (32MB each) and USER Partition 512 MB for I8200n |
br d3m0n |
1 Attachment(s) Quote:
****************************/folder/p4t...rl08jbr/shared |
Is there a way to convert those that you linked int .mmc? |
same problem i have same problem, gt-i8200n dead by using wrong firmware, someone please help! |
