Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-26-2014, 16:22   #1 (permalink)
Member: 80858
Sonork: 100.1601506
Thanks Meter: 8
i9505 in qualcomm mode
hi all i have i9505 after jtaq only qualcomm mode when i try to flash boot repair with atf i have this message
Recovery Handle Found! - (Qualcomm)
ERROR: Cannot Open COM PORT
please help team
thanks
Old 11-26-2014, 22:23   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@elfadelmed
Normally it can be just drivers problem, similar to Nokia X2 Flashing problem.
So you can update your drivers to "Nokia Emergency Connectivity" so you will have no more problem.
The easiest way to fix you problem is to manually install/update your Qualcomm Mode to Nokia Emergency Connectivity Drivers which you can find here:
C:\AdvanceBox Turbo Flasher\Drivers\
You will find a file EmergencyDownloadDriver.msi
Install That.
After your Phone is detected in Device Manager as "Nokia Emergency Connectivity"
Also, you can download Drivers here in case you cannot find it:
http://174.120.45.27/tmp/EmergencyDownloadDriver.msi
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-03-2015, 21:06   #3 (permalink)
Member: 236097
Thanks Meter: 29
dear
i have the same problem
but the phone is always recignized as qhusb port com not in nokia connectivity
possible to do it mannually ?
win xp pro
Page generated in 0.12965 seconds with 8 queries
